Hi Lee, it's wonderful~
Is it possible that the user can selecet the textstyle from dialogue box and keyin to decide the height?
Much appreciate~
For instance to change all text and mtext to Verdana with height 4.5:
(defun txtchng (sNme Ht / ss)
 (vl-load-com)
 (if (and (tblsearch "STYLE" sNme)
      (setq ss (ssget "X" (list (cons 0 "TEXT,MTEXT")
            (if (getvar "CTAB")(cons 410 (getvar "CTAB"))
               (cons 67 (- 1 (getvar "TILEMODE"))))))))
     (setq ss (mapcar 'entget (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
     (foreach e ss
       (entmod (subst (cons 7 sNme) (assoc 7 e) (subst (cons 40 Ht) (assoc 40 e) e)))))
   (princ "\n<!> No Text Found or Verdana Style Doesn't Exist <!>"))
 (princ))
(defun c:test ()
 (txtchng "VERDANA" 4.5)
 (princ))
  • Replies 30
  • Lee Mac
    13
  • migs
    5
  • CAB
    4
  • ReMark
    3
To answer your question to me.
(defun txtchng (sNme Ht / ss elst_list lst)
 (vl-load-com)
          (setq ss (ssget "X"
                                (if (getvar "CTAB")
     ;; (vl-remove-if 'listp  is only needed when the user selects the ss
     ;; so when not using window to get the ss, don't need to use it
     ;; although its only penalty for using it is time
     (setq elst_list (mapcar 'entget (mapcar 'cadr (ssnamex ss))))
     (foreach lst elst_list
       (mapcar '(lambda (new old) (setq lst (subst new old lst)))
               (list (cons 7 sNme)(cons 40 Ht))
               (list (assoc 7 e)(assoc 40 e))
       (entmod lst)
Ahh, yes - thanks CAB for the advice.
I didn't think a lambda function was needed, as I provided the subst with the arguments it needed in LISP form, but obviously this is a better way to do it.
Thanks once again
Lee
The problem is using subst which requires 3 arguments.
Using Mapcar without lambda does not lend itself to this application.
Thanks Lee~
It's marvelous!
Would u please tell me how to add ACAD search path?
It seems to be work only when I put the DCL in C:\Program Files\AutoCAD 2006\Support .
Regards~
Perhaps something like this?
Make sure you put the DCL in ACAD search path and run LISP as normal.
forgiev my ignorance, I find the answer here:
http :discussion.autodesk.com/forums/message.jspa?messageID=5533620
Go to:
Options
Files tab
Support Files Search Path
Add
Browse (select the folder where you installed the program.
Re-Load and Re-Run the program and it should work.
Thanks Lee~
It's marvelous!
Regards~
No worries, glad you like it :)
I normally have a folder in my docs entitled "ACAD Search Path", and locate this in ACAD - then I can quickly just dump dcls and lsps in there with ease. :)
Glad you like it - if you have any further questions, just ask :)
Cheers
Lee
