Hi
im new around here and looking for some help with a routine i found on here. The problem i have is that im looking for the lisp routine to select all text and convert it to my standards (verdana). i had the routine running fine last friday and it was converting the text properly but for some reason today i cannot get it working.
any help would be much appreciated
(defun C:ALLTEXT (/ entities len count ent ent_data ent_name new_style_name)
(command "STYLE" "verdana" "verdana.ttf" "" "" "" "" "")
(setq entities (ssget "X" '((0 . "TEXT")))
len (sslength entities)
count 0
);setq
(while (
(setq ent (ssname entities count)
ent_data (entget ent)
ent_name (cdr (assoc 7 ent_data))
);setq
(setq new_style_name (cons 7 "verdana"))
(setq ent_data (subst new_style_name (assoc 7 ent_data) ent_data))
(entmod ent_data)
(setq count (+ count 1))
);while
;;;runs same routine again, picking up Mtext this time.
(setq entities (ssget "X" '((0 . "MTEXT")))
count 0
);setq
(while (
);setq
(entmod ent_data)
(command "explode" ent)
);while
);defun
Error appears: error: bad argument type: lselsetp nil
any ideas?
  • Replies 30
  • Lee Mac
    13
  • migs
    5
  • CAB
    4
  • ReMark
    3
Make sure all layers are on and none are frozen. Try the routine. Does it work now?
all layers are currently on, none frozen
still not working
You made no changes to the Lisp routine itself right? Could the problem be the drawing itself? Can you test the routine on another drawing?
if you changed the routine did you run it through the Visual Lisp editor to verify functionality?
no changes were made to this routine itself
i changed my .mnu file by mistake a amended it accordingly, i tried to use this routine and just had problems with it since which has me very confused now.
ive tried running the routine both through my .mnu self made toolbar and just straight through lisp (bypassing) the .mnu
ive tried running it in a few different drawings all with the same outcome
normally means that the selection set that you are dealing with is nil.
Make you sure include an IF command in the LISP to allow for no text being present in the drawing.
Also, if you are using MTEXT instead of single-line text, then the filter list for the ssget function will need to be something like:
(list (cons 0 "TEXT,MTEXT"))
Hope this helps
PS - please enclose your code in
 [/ code] tags in future posts :)
Lee
Lee: What would have caused the routine to not work after having worked previously?
Hope this helps
Lee
thanks alot Lee
ive just started learning LISP and apart from making very simple amendments to routines ive already found it pretty much clear as much to me.
if its not too much trouble to someone is it possible to write a quick fix for me as im not sure what the IF command should be
although any help is very much appreciated
Thanks for the help but managed to work it out
added in this part instead of running the routine twice
and made a few alterations, although still not sure how the problem occurred
(list (cons 0 "TEXT,MTEXT")) [/ code]
This should work although it is written quickly and is untested. :unsure:
(defun c:txtchng (/ ss)
 (vl-load-com)
 (if (and (tblsearch "STYLE" "VERDANA")
      (setq ss (ssget "X" (list (cons 0 "TEXT,MTEXT")
            (if (getvar "CTAB")(cons 410 (getvar "CTAB"))
               (cons 67 (- 1 (getvar "TILEMODE"))))))))
     (setq ss (mapcar 'entget (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
     (foreach e ss
   (entmod (subst (cons 7 "VERDANA") (assoc 7 e) e))))
   (princ "\n<!> No Text Found or Verdana Style Doesn't Exist <!>"))
 (princ))
Accounts for a nil selection set, no text style and Mtext and text options.
I suppose you could make the txtchanger into a sub-function and call it with the text style argument, so that multiple style changes could be made:
(defun txtchng (sNme / ss)
 (vl-load-com)
 (if (and (tblsearch "STYLE" sNme)
     (foreach e ss
   (entmod (subst (cons 7 sNme) (assoc 7 e) e))))
   (princ "\n<!> No Text Found or Verdana Style Doesn't Exist <!>")))
(defun c:test ()
 (txtchng "VERDANA")
 (princ))
Hope this helps... :P
Beat me to it.
OP, that's how you would filter all text and Mtext at once, so that you only do the process once.
Nicely coded as usual, Lee. You need to teach me how to properly use mapcar one day.:shock:
Thanks Udffl... mapcar isn't too hard to grasp - as long as you remember that it applies the function to every element in a provided list and will return the result of doing so as a list of the returns...
I used to struggle with the difference between mapcar and apply... but this is overcome by realising that "apply" performs the function to the whole list and returns one result as opposed to a list of results...
Thanks for your compliments as always - I try to keep things as concise as possible at all times.. :P
Nice sig btw. :) made me laugh :)
Cheers
Lee
 (vl-load-com)
     (foreach e ss
 (princ))
I ran this routine and it worked great as far as getting to the correct style goes, but it doesnt change heights and/or widths. Anyone know of the correct way to include those in this routine?
For instance to change all text and mtext to Verdana with height 4.5:
(defun txtchng (sNme Ht / ss)
 (vl-load-com)
     (foreach e ss
       (entmod (subst (cons 7 sNme) (assoc 7 e) (subst (cons 40 Ht) (assoc 40 e) e)))))
 (princ))
(defun c:test ()
 (txtchng "VERDANA" 4.5)
 (princ))
when writing and testing the code, he could have defined a variable as global, and it wasn't setting it properly in the routine. when he restarted autocad, the global variable wouldn't be set anymore, thus, when the routine arrived at that point, it couldn't continue.
If you ran the routine once then all the MTEXT objects are exploded and there are no more MTEXT objects in the drawing.
So when you run it again, this code
       len     (sslength entities)  ; <---<<  fails here
       count 0
);setq
As Lee pointed out the selection set is now nil and
(sslength nil) causes an error.
I modified you code but did not test it.
(defun C:ALLTEXT (/ entities len count ent ent_data new_style_name)
 (if (setq entities (ssget "X" '((0 . "TEXT,MTEXT"))))
     (setq len            (sslength entities)
           count          0
     )   ;setq
     (while (< count len)
       ) ;setq
       (entmod (subst new_style_name (assoc 7 ent_data) ent_data))
       (if (= (cdr (assoc 0 ent_data)) "MTEXT")
         (command "explode" ent "")
     )   ;while
)         ;defun
CAB,
Is there any better way to phrase the following line, so that more can be added in one step?
 (vl-load-com)
        (if (getvar "CTAB") (cons 410 (getvar "CTAB"))
     (foreach e  ss
  [b][color=Red] (entmod (subst (cons 7 sNme) (assoc 7 e) (subst (cons 40 Ht) (assoc 40 e) e)))[/color][/b]))
 (princ))
(defun c:test  ()
 (princ))
I have tried using mapcar, but to no avail - but not sure why :(
[b][color=Red]    (mapcar 'entmod
                 (mapcar 'subst
                              '((cons 7 sNme) (cons 40 Ht))
                              '((assoc 7 e)   (assoc 40 e))
                                (list e)))[/color][/b]
Thanks
Lee
