Hải_Duy Posted July 25, 2023 Share Posted July 25, 2023 Quote Link to comment Share on other sites More sharing options...
devitg Posted July 25, 2023 Share Posted July 25, 2023 7 hours ago, Hải_Duy said: @Hải_Duy Please upload your sample.dwg Quote Link to comment Share on other sites More sharing options...
Hải_Duy Posted August 2, 2023 Author Share Posted August 2, 2023 Please see this cad. abc.dwg Quote Link to comment Share on other sites More sharing options...
devitg Posted August 2, 2023 Share Posted August 2, 2023 @Hải_Duy why not to use dim arc length? And not override the 3 point angular dimension abc-01.dwg Quote Link to comment Share on other sites More sharing options...
Hải_Duy Posted August 3, 2023 Author Share Posted August 3, 2023 (edited) this is i am assuming a short and want to have a lisp that adjusts polyline to dimension distance so with many spacing lines overlapping polyline like this you have an idea to adjust distance from polyline to line size ? 123.dwg Edited August 3, 2023 by Hải_Duy Quote Link to comment Share on other sites More sharing options...
Tsuky Posted August 3, 2023 Share Posted August 3, 2023 This can help you? (vl-load-com) (defun c:Dim_PolyArc ( / js AcDoc modelSpace n ename obj pr dist_start dist_end pt_start pt_end pt_sel seg_len seg_bulge pos offset ang_base ang rad alpha pt_cen) (princ "\nSelect polylines.") (while (null (setq js (ssget '((0 . "LWPOLYLINE"))))) (princ "\nSelection is empty, or aren't POLYLINES!") ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) modelSpace (vla-get-ModelSpace Acdoc) ) (vla-StartUndoMark AcDoc) (repeat (setq n (sslength js)) (setq ename (ssname js (setq n (1- n))) obj (vlax-ename->vla-object ename) pr -1 ) (repeat (fix (vlax-curve-getEndParam obj)) (setq dist_start (vlax-curve-GetDistAtParam obj (setq pr (1+ pr))) dist_end (vlax-curve-GetDistAtParam obj (1+ pr)) pt_start (vlax-curve-GetPointAtParam obj pr) pt_sel (vlax-curve-GetPointAtParam obj (+ pr 0.5)) pt_end (vlax-curve-GetPointAtParam obj (1+ pr)) seg_len (- dist_end dist_start) seg_bulge (vla-GetBulge obj pr) ang_base (angle pt_start pt_end) ) (if (or (not offset) (and (not (eq (getvar "USERR1") (* pi 0.5))) (not (eq (getvar "USERR1") (* pi 1.5))))) (progn (initget 1) (setq pos (getpoint pt_sel "\nPosition for all dimensions: ") offset (distance pt_sel pos) ang (angle pt_sel pos) ) (setvar "USERR1" (if (eq (rem pi (- ang ang_base)) pi) (* 0.5 pi) (* 1.5 pi))) ) ) (if (not (zerop seg_bulge)) (progn (setq rad (/ seg_len (* 4.0 (atan seg_bulge))) alpha (+ (angle pt_start pt_end) (- (* pi 0.5) (* 2.0 (atan seg_bulge)))) pt_cen (polar pt_start alpha rad) ) (vlax-put (vla-AddDimAngular modelSpace (vlax-3d-point pt_cen) (vlax-3d-point pt_start) (vlax-3d-point pt_end) (vlax-3d-point (polar pt_sel (+ ang_base (getvar "USERR1")) offset)) ) 'TextOverride (vl-string-subst (getvar "DIMDSEP") "." (rtos seg_len (getvar "DIMLUNIT") (getvar "DIMDEC"))) ) ) (vla-AddDimAligned modelSpace (vlax-3d-point pt_start) (vlax-3d-point pt_end) (vlax-3d-point (polar pt_sel (+ ang_base (getvar "USERR1")) offset)) ) ) ) ) (vla-EndUndoMark AcDoc) (prin1) ) 3 Quote Link to comment Share on other sites More sharing options...
Hải_Duy Posted August 4, 2023 Author Share Posted August 4, 2023 this is what i need for my work, thank you very much 13 hours ago, Tsuky said: This can help you? (vl-load-com) (defun c:Dim_PolyArc ( / js AcDoc modelSpace n ename obj pr dist_start dist_end pt_start pt_end pt_sel seg_len seg_bulge pos offset ang_base ang rad alpha pt_cen) (princ "\nSelect polylines.") (while (null (setq js (ssget '((0 . "LWPOLYLINE"))))) (princ "\nSelection is empty, or aren't POLYLINES!") ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) modelSpace (vla-get-ModelSpace Acdoc) ) (vla-StartUndoMark AcDoc) (repeat (setq n (sslength js)) (setq ename (ssname js (setq n (1- n))) obj (vlax-ename->vla-object ename) pr -1 ) (repeat (fix (vlax-curve-getEndParam obj)) (setq dist_start (vlax-curve-GetDistAtParam obj (setq pr (1+ pr))) dist_end (vlax-curve-GetDistAtParam obj (1+ pr)) pt_start (vlax-curve-GetPointAtParam obj pr) pt_sel (vlax-curve-GetPointAtParam obj (+ pr 0.5)) pt_end (vlax-curve-GetPointAtParam obj (1+ pr)) seg_len (- dist_end dist_start) seg_bulge (vla-GetBulge obj pr) ang_base (angle pt_start pt_end) ) (if (or (not offset) (and (not (eq (getvar "USERR1") (* pi 0.5))) (not (eq (getvar "USERR1") (* pi 1.5))))) (progn (initget 1) (setq pos (getpoint pt_sel "\nPosition for all dimensions: ") offset (distance pt_sel pos) ang (angle pt_sel pos) ) (setvar "USERR1" (if (eq (rem pi (- ang ang_base)) pi) (* 0.5 pi) (* 1.5 pi))) ) ) (if (not (zerop seg_bulge)) (progn (setq rad (/ seg_len (* 4.0 (atan seg_bulge))) alpha (+ (angle pt_start pt_end) (- (* pi 0.5) (* 2.0 (atan seg_bulge)))) pt_cen (polar pt_start alpha rad) ) (vlax-put (vla-AddDimAngular modelSpace (vlax-3d-point pt_cen) (vlax-3d-point pt_start) (vlax-3d-point pt_end) (vlax-3d-point (polar pt_sel (+ ang_base (getvar "USERR1")) offset)) ) 'TextOverride (vl-string-subst (getvar "DIMDSEP") "." (rtos seg_len (getvar "DIMLUNIT") (getvar "DIMDEC"))) ) ) (vla-AddDimAligned modelSpace (vlax-3d-point pt_start) (vlax-3d-point pt_end) (vlax-3d-point (polar pt_sel (+ ang_base (getvar "USERR1")) offset)) ) ) ) ) (vla-EndUndoMark AcDoc) (prin1) ) Quote Link to comment Share on other sites More sharing options...
