Have You Tried: Properties Palette
The AutoCAD Blog
For the Have You Tried this month, we are going to take a deep dive into the Properties palette.
Have you ever added an object onto the wrong layer? Or maybe assigned a set of objects the wrong color? Updating these properties are just some basic examples of what the Properties palette can do. Each object has a set of properties that can be modified in several ways. The Properties palette is an efficient way to modify several properties at once.
In this Have You Tried, we’ll cover:
  • Displaying the Properties palette and working with the controls on it
  • Editing the properties of an object and multiple objects
  • Filtering objects by type
  • Finding geometric information
  • Closing certain object types
  • Checking for and modifying non-coplanar objects (AutoCAD Only)
Learn how the Properties palette can help you easily modify objects with the step-by-step examples in Have You Tried: The Properties Palette topic.
AutoCAD Properties palette example
Keep the Feedback Coming
Thanks for all the great feedback submitted so far. Because of the great feedback, we have been able to improve the topics in the AutoCAD Online Help system.
The best way to submit feedback is by using the “Was this helpful?” section located at the bottom of every Help topic. Let us know what you like or don’t like about a topic or provide suggestions for other subjects that you’d like to see covered in greater detail. The more specific your comments, the better.
The post Have You Tried: Properties Palette appeared first on AutoCAD Blog.
View the full article
