Find entity on layer "unprintable".... in selected blocks
X11start
I would like to find an "elegant" way to check if, in selected blocks, there are entities on "unprintable" layers.
If I find these entities, I can send an ALERT that warns me and puts a circle around the invalid block.
Google for any edit block entity lisp, then rather than change item, check its layer if it no plot, then draw a circle at say insertion point.
Edited by BIGAL
Made This to just display a list of block names.
All Layers Are Plottable
or
3 Blocks Found With Entities on Non-Plottable Layers:
block name 1
block name 2
block name 3
(defun C:foo (/ laylst blklst num)
  (vlax-for layobj (vla-get-Layers (vla-get-activedocument (vlax-get-acad-object)))
    (if (= (vlax-get-property layobj 'plottable) :vlax-False)
      (setq laylst (cons (vla-get-name layobj) laylst))
  (cond
    ((> (length laylst) 0)
      (vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))  ;lists all block definitions in the drawing
        (vlax-for obj blk  ;for each object in the block
          (cond
            ((and (not (member (vla-get-name blk) blklst)) (member (vla-get-layer obj) laylst))
                  (setq blklst (cons (vla-get-name blk) blklst))
      (if (> (setq num (length blklst)) 0)
          (prompt (strcat "\n" (itoa num) " Blocks Found With Entities on Non-Plottable Layers:"))
          (foreach item Blklst
            (prompt (strcat "\n" item))
          (if (> num 5)
            (textpage)
        (prompt "\nNo Blocks Found")
    (t
      (prompt "\nAll layers are Plottable")
I test the lisp, but it tells me "All layers are Plottable": it is considered "unprintable" only "Defpoints" (and inserted in the LAYLST variable), while my layer "UNPRINTABLE" is not considered. So in the attached dwg he considers me both the correct blocks.
Is it possible to modify the lisp to analyze only the selected blocks and not all the blocks of the drawing?
Many thanks for the answers!
UNPRINTABLE.dwg
Maybe I can change :
(vlax-for layobj (vla-get-Layers (vla-get-activedocument (vlax-get-acad-object))) (if (= (vlax-get-property layobj 'plottable) :vlax-False) (setq laylst (cons (vla-get-name layobj) laylst)) ) )
with the lisp of Jimmy Bergmark: Layer-State
Give this a shot and let me know. :)
(defun c:Test (/ int sel ent add fnd obj bkn bks )
  ;;	Author : Tharwat Al Choufi			;;
  ;; website: https://autolispprograms.wordpress.com	;;
  (and (princ "\nSelect blocks to check for unprintable layer existed : ")
       (setq int -1 add (ssadd) sel (ssget '((0 . "INSERT"))))
       (while (setq int (1+ int) ent (ssname sel int))
         (and (setq obj (tblobjname "BLOCK" (setq bkn (cdr (assoc 2 (entget ent))))))
              (or (and (member bkn bks)
                       (ssadd ent add)
                  (while (and (not fnd) (setq obj (entnext obj)))
                    (and (setq fnd (member '(8 . "UNPRINTABLE") (entget obj)))
                         (ssadd ent add)
                         (setq bks (cons bkn bks))
         (setq fnd nil)
  (sssetfirst nil add)
Your @Tharwat solution is also interesting: your lisp finds the layers contained in the blocks, regardless of whether they are printable or unprintable... It can be a valid solution: I provide a list of layers that should NOT be present in the blocks with this lisp I see if there is any block that instead contains them. But I would prefer to use the @Mhupp proposal: it is more generic and would also work with new "forbidden" layers, inserted later.
Thanks anyway to both of you: I really appreciate that you wrote lisp code just for me!
This go ?
                       (ssadd ent add)
                    (and (setq fnd (zerop (cdr (assoc 290 (entget (tblobjname "LAYER" (cdr (assoc 8 (entget obj)))))))))
                         (ssadd ent add)
         (setq fnd nil)
Magic!!  Many thanks: it works perfectly!
You're welcome anytime. :)
