Save as with extension error
RBrigido
Hi guys,
How's the farm? :D
I'm having a headache here with a simple lisp that I can't fix.
Just to let you know, I'm using BricsCAD. See the code below:
Quote
(defun c:SaveAsUserDefined ()
  (vl-load-com) ; Load the COM (Component Object Model) functions for AutoCAD
  ; Prompt the user for the new location and file name
  (setq new-file (getfiled "Save as" "" "dwg" 16))
  ; Check if the user selected a valid location/name
  (if new-file
      ; Save the current drawing as the new file
      (vla-SaveAs (vla-get-activedocument (vlax-get-acad-object)) new-file)
      (princ (strcat "\nDrawing saved as: " new-file))
    (princ "\nOperation canceled by the user.")
I don't know why, when I try to use that lisp, I'm not be able to change the extension. A window appears asking me to save in some location, I choose and put a name, see below:
But when it's save, always is as .DXF extension.
Any ideas?
This is the similar line I use, I have the version at the end of it, not sure if that makes a difference? BricsCAD can be funny sometimes with VLA - commands I believe.
(vla-SaveAs (vla-get-ActiveDocument (vlax-get-acad-object)) (strcat (getvar "dwgprefix") myfilename ".dwg") ac2010_dwg)
(One of our clients lives in the past with ac2010, maybe I should update this one day)
For opening files :
For saving files :
(setq new-file (getfiled "Save as" "" "dwg" 1))
Hi guys,
Thanks for all your reply.
@Steven P's answer was pretty resolute for me.
If you have BricsCAD or have the same problem with AutoCAD, I'll be sharing the Lisp Routine below:
Quote
(defun c:zzzzzz()
   (vl-load-com) ; Load COM (Component Object Model) functions into AutoCAD
   ; Prompt the user for the new location and name of the file
   (if new-file
       (vla-SaveAs (vla-get-ActiveDocument (vlax-get-acad-object)) new-file ac2010_dwg)
   (prince)
Thank you all for try to help me !!
Best wishes,
Rodrigo Brigido.
