Ish Posted July 20, 2023 Share Posted July 20, 2023 Dear team, I want to make hatching in multiple closed polyline with layer Hatch pattern: any default but not a solid one After selection/ pick all pline , draw hatch and after I press enter or escape button , hatch pattern in AutoCAD return to default solid pattern, not that one used recently. So I need a lisp for that. Thanks Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted July 20, 2023 Share Posted July 20, 2023 What do you mean: polyline with layer? Anyway, command MPH (for Hatch Multiple Polylines) the pattern is ANSI31; you can change it in the function hatch_closed_polyline ;; Hatch Multiple Polylines (defun c:hmp ( / ss sc i) (setq sc (getreal "\nScale: ")) ;; or do: (setq sc 1.0) ;; or whatever factor (prompt "\nSelect Closed Polylines to Hatch: ") (setq ss (ssget (list (cons 0 "*POLYLINE") ))) ;;(cons 70 1) ;;(hatch_closed_polyline ss sc) (setq i 0) (repeat (sslength ss) (hatch_closed_polyline (ssadd (ssname ss i)) sc) (setq i (+ i 1)) ) ) ;; slightly modified from this code: ;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/entmake-hatch-with-base-point-or-object-polyline-entity-name/m-p/8703197#M383362 (defun hatch_closed_polyline (ss sc / cnt e hList pat) (setq pat "ANSI31") ;; adapt to your needs (if (= 0.0 sc) (setq sc 1.0) ) (setq cnt (sslength ss)) (while (<= 0 (setq cnt (1- cnt))) (setq e (ssname ss cnt)) (if (setq tmp (CreateHatchList e)) (setq hList (cons tmp hList)) );if );while (setq hList (reverse hList)) (if (entmakex-hatch hList 0.0 pat sc) (prompt "\nSuccess!") (prompt "\n...Failure.") );if (princ) );defun (defun CreateHatchList (e / i j pList found) (foreach i (entget e) (if (= 10 (car i)) (progn (setq pList (cons i pList)) (setq found nil j (member i (entget e))) (while (and (not found) (< 0 (length j))) (if (= 42 (car (car j))) (setq pList (cons (car j) pList) found t) );if (setq j (cdr j)) );while );progn );if );foreach (reverse pList) );defun ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun entmakex-hatch (l a n s) ;; By ElpanovEvgeniy ;; L - list point ;; A - angle hatch ;; N - name pattern ;; S - scale ;; return - hatch ename (entmakex (apply 'append (list (list '(0 . "HATCH") '(100 . "AcDbEntity") '(410 . "Model") '(100 . "AcDbHatch") '(10 0.0 0.0 0.0) '(210 0.0 0.0 1.0) (cons 2 n) (if (= n "SOLID") '(70 . 1) '(70 . 0) ) ;_ if '(71 . 0) (cons 91 (length l)) ) ;_ list (apply 'append (mapcar '(lambda (a) (apply 'append (list (list '(92 . 7) '(72 . 1) '(73 . 1) (cons 93 (/ (length a) 2))) (mapcar '(lambda (b) b) a) '((97 . 0)) ) ;_ list ) ;_ apply ) ;_ lambda l ) ;_ mapcar ) ;_ apply (list '(75 . 0) '(76 . 1) (cons 52 a) (cons 41 s) '(77 . 0) '(78 . 1) (cons 53 a) '(43 . 0.) '(44 . 0.) '(45 . 1.) '(46 . 1.) '(79 . 0) '(47 . 1.) '(98 . 2) '(10 0. 0. 0.0) '(10 0. 0. 0.0) '(451 . 0) '(460 . 0.0) '(461 . 0.0) '(452 . 1) '(462 . 1.0) '(453 . 2) '(463 . 0.0) '(463 . 1.0) '(470 . "ANSI31") ) ;_ list ) ;_ list ) ;_ apply ) ;_ entmakex ) ;_ defun 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted July 20, 2023 Author Share Posted July 20, 2023 Thanks, almost as I want, Just please provide, 1. Hatch pattern name on command prompt also to change: Like scale is coming, 2. Hatching must be in separate layer ex: hatching 3: provide also, pick point option for hatching, Currently asking select closed polyline to hatch, select objects: Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 21, 2023 Share Posted July 21, 2023 3 use Hatch has the pick point option. Quote Link to comment Share on other sites More sharing options...
