pyou Posted July 19, 2023 Posted July 19, 2023 Hi Is there a way to match text entity, but keep Alphabets for the second text? For example i have text 123.50 , the second entity is CL1.50. The result I am looking to get is CL123.50 I am using this lisp command currently and adding text prefix after matching the text. Hoping you all could help me to get around it? (defun c:mt (/ cEnt mEnt) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (while (and (setq mEnt (car (nentsel "\nSelect Destination Text: "))) (member (cdr (assoc 0 (entget mEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (entmod (subst (assoc 1 (entget cEnt)) (assoc 1 (entget mEnt)) (entget mEnt)))) (redraw cEnt 4)) (princ "\n<!> Incorrect Selection <!>")) (princ)) Quote
Emmanuel Delay Posted July 20, 2023 Posted July 20, 2023 (edited) Like this? What it does: I expect 1number between a prefix and postfix (both of which can be empty) So for example: destination = 23.6GT56, source = 123.50 => result = 123.50GT56 From the moment the number starts the prefix ends; from the moment the number stops then all the rest is postfix. It doesn't see 12E+3 (which is 12000) as a number. That's a TODO. (defun c:mt (/ cEnt mEnt newString) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) ;; user selects source TEXT/MTEXT/ATTRIB cEnt (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (while (and (setq mEnt (car (nentsel "\nSelect Destination Text: "))) ;; user selects destination TEXT/MTEXT/ATTRIB mEnt (member (cdr (assoc 0 (entget mEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (setq newString (keepAlphabets (cdr (assoc 1 (entget cEnt))) (cdr (assoc 1 (entget mEnt))) )) (princ newString) (entmod (subst (cons 1 newString) (assoc 1 (entget mEnt)) (entget mEnt) )) ) (redraw cEnt 4) ) (princ "\n<!> Incorrect Selection <!>") ) (princ) ) ;; For example src = "123.50" , dest = "CL1.50TG" . result = "CL123.50TG" (defun keepAlphabets ( src dest / chars a prefix num post) (setq prefix "") (setq num "") (setq post "") ;; string to characters list (setq chars (vl-string->list dest)) (foreach a chars (if (and (= post "") (or (= a 46) (< 47 a 58))) ;; character is a "." or [0->9]. Skip this if the postcript has started (progn (setq num (strcat num (chr a))) ) (progn (if (= num "") (setq prefix (strcat prefix (chr a))) (setq post (strcat post (chr a))) ) ) ) ) (strcat prefix src post) ) Edited July 20, 2023 by Emmanuel Delay 1 Quote
pyou Posted July 20, 2023 Author Posted July 20, 2023 12 hours ago, Emmanuel Delay said: Like this? What it does: I expect 1number between a prefix and postfix (both of which can be empty) So for example: destination = 23.6GT56, source = 123.50 => result = 123.50GT56 From the moment the number starts the prefix ends; from the moment the number stops then all the rest is postfix. It doesn't see 12E+3 (which is 12000) as a number. That's a TODO. (defun c:mt (/ cEnt mEnt newString) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) ;; user selects source TEXT/MTEXT/ATTRIB cEnt (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (while (and (setq mEnt (car (nentsel "\nSelect Destination Text: "))) ;; user selects destination TEXT/MTEXT/ATTRIB mEnt (member (cdr (assoc 0 (entget mEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (setq newString (keepAlphabets (cdr (assoc 1 (entget cEnt))) (cdr (assoc 1 (entget mEnt))) )) (princ newString) (entmod (subst (cons 1 newString) (assoc 1 (entget mEnt)) (entget mEnt) )) ) (redraw cEnt 4) ) (princ "\n<!> Incorrect Selection <!>") ) (princ) ) ;; For example src = "123.50" , dest = "CL1.50TG" . result = "CL123.50TG" (defun keepAlphabets ( src dest / chars a prefix num post) (setq prefix "") (setq num "") (setq post "") ;; string to characters list (setq chars (vl-string->list dest)) (foreach a chars (if (and (= post "") (or (= a 46) (< 47 a 58))) ;; character is a "." or [0->9]. Skip this if the postcript has started (progn (setq num (strcat num (chr a))) ) (progn (if (= num "") (setq prefix (strcat prefix (chr a))) (setq post (strcat post (chr a))) ) ) ) ) (strcat prefix src post) ) Emmanuel Delay, Thank you very much for your Help! It works excellent! 1 Quote
