leonucadomi Posted July 17, 2023 Share Posted July 17, 2023 hello: I modified some of my routines. and now every time I open a file opens the autocad help page. I managed to deactivate F1. but it happens to me every time I open a file. any ideas... thanks Quote Link to comment Share on other sites More sharing options...
mhupp Posted July 18, 2023 Share Posted July 18, 2023 (edited) Sounds like your modification is running (command "") without calling a command. This acts like hitting enter or right click and telling AutoCAD to repeat last command. If you repeat last command and their isn't a previous one to repeat (you just opened the drawing) it will execute the help command. Check to make sure your not calling something when it loads, And all Code is within defun brackets. Edited July 18, 2023 by mhupp 1 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted July 18, 2023 Share Posted July 18, 2023 Was about to say the same, when you open a file and hit 'enter' the default is to open the help pages. So if your LISPs have the equivalent of an enter before doing anything else and on opening this is what will happen 1 Quote Link to comment Share on other sites More sharing options...
