Kemion Posted July 17, 2023 Posted July 17, 2023 Hello. I've run into several types of objects (ceiling grids, masking blocks) that display and plot an xyz origin. How can these be hidden? Thanks! Quote
BIGAL Posted July 18, 2023 Posted July 18, 2023 If the grids are 3D solids then they will block underneath objects when viewed say in Plan view. So what about 2 options move the grids to a Z below the blocks, or try draworder. No dwg to test, always a good idea to post a dwg for this type of question. Quote
Kemion Posted July 18, 2023 Author Posted July 18, 2023 Hello. Yes, thank you for taking a look. These are mainly AEC ceiling grids, but the origins are attached to other objects as well. I'm inclined to suspect perhaps that there is a system variable somewhere, or a property to control the visibility - but nothing I can find. RCP.dwg Quote
