raymarcher Posted July 17, 2023 Posted July 17, 2023 Hello, Is there a way to convert closed 3D Polylines to a mesh? Non manual, in batch? My current workaround is using Rhino 3D. It works perfect using this tool: https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/meshpolyline.htm Next workaround is trying Dynamo. The closest I can get is to use this lisp using Surface Patch. I am able to convert most without failure, but 10% fails. Plus once converted to mesh it has excessive triangles. https://www.cadforum.cz/en/how-to-convert-3d-polylines-to-3d-surfaces-tip9097 I also tried CADTools. Greetings, Frederik Quote
BIGAL Posted July 18, 2023 Posted July 18, 2023 Are the 3d plines in 1 face, if so then pface may do what you want. Quote
