leonucadomi Posted July 13, 2023 Share Posted July 13, 2023 hello : I use autocad 2013. I have some files that when trying to copy to other files suddenly everything closes and does not give a chance to save. Does anyone have a solution or comment? thanks Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 13, 2023 Share Posted July 13, 2023 See if this helps: Copy and paste hangs for a long time or fails to work in AutoCAD Does it fail on Copy or are you Pasting when it fails? What are the computer specifications and operating system used? AutoCAD 2013 is pretty old and if running on a newer system there could be issues with compatibility. Have you tried other methods to copy the files? Did you create the files or someone else? 1 Quote Link to comment Share on other sites More sharing options...
