cagorskij Posted July 13, 2023 Share Posted July 13, 2023 Hello o/ I'm trying to adjust the second value in a list. I'm not entirely sure about lists & the functions used to manipulate them, but this is what im trying (and failing): (setq brgZ (list deg minu sec)) (setq (cadr brgZ) (+ (cadr brgZ) 1)) & i am getting the error: error : invalid-identifier <(CADR BRGZ)> ; expected <SYMBOL> at [setq] I've tried looking up how to modify the any value individually in a list, but am kind of struggling to find answers. Explanations are super appreciated (I assume this is a really simple thing >_<) Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted July 13, 2023 Share Posted July 13, 2023 (edited) Read this: https://www.afralisp.net/autolisp/tutorials/list-manipulation.php You want the subst function. Syntax : (subst newitem olditem lst) in your example (setq brgZ (subst (+ 1 (cadr brgZ)) (cadr brgZ) brgZ) ) Edited July 13, 2023 by Emmanuel Delay 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted July 13, 2023 Share Posted July 13, 2023 (setq ..... _) wants a variable such as (setq brgZ ......) In your example you are giving it a value rather than the variable 1 Quote Link to comment Share on other sites More sharing options...
cagorskij Posted July 13, 2023 Author Share Posted July 13, 2023 thank you both! 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 14, 2023 Share Posted July 14, 2023 (edited) On 7/13/2023 at 7:54 AM, Emmanuel Delay said: Read this: https://www.afralisp.net/autolisp/tutorials/list-manipulation.php You want the subst function. Syntax : (subst newitem olditem lst) in your example (setq brgZ (subst (+ 1 (cadr brgZ)) (cadr brgZ) brgZ) ) I wouldn't recommend using subst for this purpose, as subst will replace all occurrences within the list - consider the following example: _$ (setq brgZ '(10 10 10)) (10 10 10) _$ (subst (1+ (cadr brgZ)) (cadr brgZ) brgZ) (11 11 11) Instead, I would use simple list construction - (setq brgZ (list (car brgZ) (1+ (cadr brgZ)) (caddr brgZ))) Alternatively, you could use mapcar, but this somewhat obscures the intent: (setq brgZ (mapcar '+ brgZ '(0 1 0))) Edited July 14, 2023 by Lee Mac 3 Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted July 18, 2023 Share Posted July 18, 2023 How about a general "replace nth element" (defun c:test ( / ) ;; for example (setq deg 17) (setq minu 34) (setq sec 55) (setq brgZ (list deg minu sec)) ;; (setq (cadr brgZ) (+ (cadr brgZ) 1)) (setq brgZ (replace_nth brgZ 1 (+ (cadr brgZ) 1) )) ) ;; replaces then nth item of a list (defun replace_nth (lst n replaceBy / i res a) (setq res (list)) (setq i 0) (foreach a lst (if (= i n) (setq res (append res (list replaceBy))) (setq res (append res (list a))) ) (setq i (+ i 1)) ) res ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 18, 2023 Share Posted July 18, 2023 Here are some alternatives: Subst Nth 1 Quote Link to comment Share on other sites More sharing options...
