setq with lists & cadr
cagorskij
Hello o/
I'm trying to adjust the second value in a list.
I'm not entirely sure about lists & the functions used to manipulate them, but this is what im trying (and failing):
(setq brgZ (list deg minu sec))
(setq (cadr brgZ) (+ (cadr brgZ) 1))
& i am getting the error:
error : invalid-identifier <(CADR BRGZ)> ; expected <SYMBOL> at [setq]
I've tried looking up how to modify the any value individually in a list, but am kind of struggling to find answers.
Explanations are super appreciated (I assume this is a really simple thing >_<)
(setq ..... _) wants a variable such as (setq brgZ ......)
In your example you are giving it a value rather than the variable
On 7/13/2023 at 7:54 AM, Emmanuel Delay said:
Read this:
https://www.afralisp.net/autolisp/tutorials/list-manipulation.php
You want the subst function.
Syntax : (subst newitem olditem lst)
in your example
(setq brgZ
  (subst (+ 1 (cadr brgZ)) (cadr brgZ)  brgZ)
I wouldn't recommend using subst for this purpose, as subst will replace all occurrences within the list - consider the following example:
_$ (setq brgZ '(10 10 10))
(10 10 10)
_$ (subst (1+ (cadr brgZ)) (cadr brgZ) brgZ)
(11 11 11)
Instead, I would use simple list construction -
(setq brgZ (list (car brgZ) (1+ (cadr brgZ)) (caddr brgZ)))
Alternatively, you could use mapcar, but this somewhat obscures the intent:
(setq brgZ (mapcar '+ brgZ '(0 1 0)))
Edited by Lee Mac
  • Like 3
How about a general "replace nth element"
(defun c:test ( / )
	;; for example
	(setq deg 17)
	(setq minu 34)
	(setq sec 55)
	;; (setq (cadr brgZ) (+ (cadr brgZ) 1))
	(setq brgZ (replace_nth brgZ 1 (+ (cadr brgZ) 1) ))
;; replaces then nth item of a list
(defun replace_nth (lst n replaceBy / i res a)
	(setq res (list))
	(setq i 0)
	(foreach a lst
		(if (= i n)
			(setq res (append res (list replaceBy)))
			(setq res (append res (list a)))
		(setq i (+ i 1))
	res
