leonucadomi Posted July 12, 2023 Share Posted July 12, 2023 hello: I have a code that extracts the data from a block with attributes. but you have to select the block with click. knowing that the block is called "block1 or block2" always I want to ask for your help to modify the code and not have to select anything with click. if not do it automatically. thanks here the code... (defun LM:vl-getattributevalue ( blk tag );LEE MAC (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att))) (vlax-invoke blk 'getattributes)) ) (defun c:pru () (while (setq obj_block (vlax-ename->vla-object (car (entsel "\nSelecciona bloque: ")))) (setq dato2 (LM:vl-getattributevalue obj_block "DATO2")) (princ dato2) ) ) Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted July 12, 2023 Author Share Posted July 12, 2023 I think this routine can help me but I don't know how to use it, does anyone know? ;; Get Attribute Value - Lee Mac ;; Returns the value held by the specified tag within the supplied block, if present. ;; blk - [vla] VLA Block Reference Object ;; tag - [str] Attribute TagString ;; Returns: [str] Attribute value, else nil if tag is not found. (defun LM:vl-getattributevalue ( blk tag ) (setq tag (strcase tag)) (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att))) (vlax-invoke blk 'getattributes)) ) Quote Link to comment Share on other sites More sharing options...
leonucadomi Posted July 12, 2023 Author Share Posted July 12, 2023 I already got it. thanks Quote Link to comment Share on other sites More sharing options...
mhupp Posted July 12, 2023 Share Posted July 12, 2023 Even simpler Yet. but only works with newer versions of AutoCAD. also setpropertyvalue! (defun c:pru (/) (while (setq blk (car (entsel "\nSelecciona bloque: "))) (princ (getpropertyvalue blk "DATO2")) ) ) 1 Quote Link to comment Share on other sites More sharing options...
