j2lstaples Posted July 12, 2023 Posted July 12, 2023 Hello everyone, I've been coding a lot the past few days and I just wanted to share my code for those who may have some use for them, and also for me to keep track of my progress. ;********************************************************; ;; MA:perp-test - Test if two angles are perpendicular ;; Arguments: ;; - a (float): First angle in radians ;; - b (float): Second angle in radians ;; - tol (float): Tolerance value for comparison ;; Returns: ;; - test (bool): True if the angles are perpendicular within the given tolerance, False otherwise ;; Usage: (MA:perp-test a b tol) (defun MA:perp-test (a b tol / test) (if (and a b tol) (if (< (abs (- (abs (cos a)) (abs (sin b)))) tol) (setq test T) (setq test nil) ) ) ) This is a very simple script for when you want to compare two angles, especially of blocks you're working with. This can be modified to where it has a default tolerance value for orthogonality, but that would be a good exercise for you guys to test for yourselves. 4 Quote
Emmanuel Delay Posted July 13, 2023 Posted July 13, 2023 oh yeah, checking if one's cosinus is the other's sinus (absolute value). I'll steal this one. 1 Quote
j2lstaples Posted July 13, 2023 Author Posted July 13, 2023 On 7/13/2023 at 8:02 AM, Emmanuel Delay said: oh yeah, checking if one's cosinus is the other's sinus (absolute value). I'll steal this one. it feels great when someone you used as a reference likes your code, lol. Cheers Emmanuel. Quote
Lee Mac Posted July 13, 2023 Posted July 13, 2023 Congrats on your function - note that you can reduce it to the following to achieve the same result: (defun MA:perp-test ( a b tol ) (< (abs (- (abs (cos a)) (abs (sin b)))) tol) ) Personally, the validity of the arguments should be the responsibility of the caller. 1 Quote
j2lstaples Posted July 14, 2023 Author Posted July 14, 2023 On 7/13/2023 at 8:26 PM, Lee Mac said: Congrats on your function - note that you can reduce it to the following to achieve the same result: (defun MA:perp-test ( a b tol ) (< (abs (- (abs (cos a)) (abs (sin b)))) tol) ) Personally, the validity of the arguments should be the responsibility of the caller. Expand That looks insanely neater than what I did. I guess I wasn't thinking about refactoring the code. I need to work on recognizing things like this better. Quote
Lee Mac Posted July 16, 2023 Posted July 16, 2023 On 7/14/2023 at 7:22 PM, j2lstaples said: That looks insanely neater than what I did. I guess I wasn't thinking about refactoring the code. I need to work on recognizing things like this better. It's the same expression as is present in your code, you just don't need to explicitly assign a value to a boolean variable in order to return the boolean value. Quote
ronjonp Posted July 19, 2023 Posted July 19, 2023 On 7/13/2023 at 8:26 PM, Lee Mac said: Personally, the validity of the arguments should be the responsibility of the caller. Agree 100%. Quote
lrm Posted July 19, 2023 Posted July 19, 2023 (edited) Be careful of how "tol" is used in your program. Due to the slope of the sine function being close to 45 degrees near zero degrees compared to its slope near 90 degress (almost flat) you wil get more precision when angle "a" i,s closer to 0 degrees than when it's near 90 degrees. Your program should use sin(a) cos(b) for when a is < 45 and sin(b), cos(a) otherwise. In each of the following examples, the angle difference between a and b is 89.7 degrees. Note how the difference varies as a function of the angles used. Edited July 19, 2023 by lrm 1 Quote
fuccaro Posted July 20, 2023 Posted July 20, 2023 My solution: start this lisp and click 3 times on the screen. Your clicks are assigned to points A, B and C. It will return TRUE only If AB is perpendicular to BC (defun c:ra( / a b c c1 c2 h fuzz) ;right angle (setq a (getpoint) b (getpoint) c (getpoint) fuzz 1e-6) (equal (+ (* (setq c1 (distance a b)) c1) (* (setq c2 (distance b c)) c2)) (* (setq h (distance a c)) h) fuzz) ) Quote
dexus Posted July 20, 2023 Posted July 20, 2023 On 7/20/2023 at 8:13 AM, fuccaro said: My solution: start this lisp and click 3 times on the screen. Your clicks are assigned to points A, B and C. It will return TRUE only If AB is perpendicular to BC (defun c:ra( / a b c c1 c2 h fuzz) ;right angle (setq a (getpoint) b (getpoint) c (getpoint) fuzz 1e-6) (equal (+ (* (setq c1 (distance a b)) c1) (* (setq c2 (distance b c)) c2)) (* (setq h (distance a c)) h) fuzz) ) Expand Nice and easy to understand function. You may want to consider using a simple square-function so you don't have to keep saving variables and makes the code more readable. (defun sqr (x) (* x x)) (defun c:ra ( / a b c c1 c2 h fuzz) ;right angle (setq a (getpoint) b (getpoint) c (getpoint) fuzz 1e-6) (equal (+ (sqr (distance a b)) (sqr (distance b c))) (sqr (distance a c)) fuzz) ) 1 Quote
fuccaro Posted July 20, 2023 Posted July 20, 2023 @dexus: Nice point! If writing speed is concerned, your code is better. If running speed is important, my solution will be (probable) faster with say 0.1% @ Lee Mac: Not just Pythagoras; even CADTutor could be proud for the lisps and all the other stuffs posted here in this forum! Quote
