zeichner Posted July 12, 2023 Posted July 12, 2023 Hello, I am looking for a simple, inexpensive program where you can: - merge layers to the main layer - Select all objects and assign layer color Any ideas? Quote
CyberAngel Posted July 12, 2023 Posted July 12, 2023 It would help to know what you need to do. Do you want to open a DWG or just process the data? Is this for 3D printing or CNC milling? Is it for importing into some other 3D software? Once everything is on one layer, what's the point of assigning color to a layer? There are alternatives to AutoCAD that will let you manage layers. BricsCAD and DraftSight, for instance, have a lot of functionality for much less money than AutoCAD. Quote
zeichner Posted July 13, 2023 Author Posted July 13, 2023 We need to convert the dwg to the appropriate form and save it so that it can be further processed by an Access tool. In the end, a pdf file is generated (parts list with drawing). We get the dwg from the design department and first have to remove margins and header information. Then the layers are combined into one and positioned appropriately. I would like to see a tool that is either free or only requires a one-time payment. I have already looked at QCAD as I use this myself, however, merging layers is not so straightforward. Quote
CyberAngel Posted July 13, 2023 Posted July 13, 2023 Sorry, you're getting this drawing from another department in your own company? Can't they export a BOM to a spreadsheet and send you a PDF of their own drawing? I'm sure it's more complicated than it sounds, but the more information you can give us, the better we can advise you. Quote
zeichner Posted July 14, 2023 Author Posted July 14, 2023 I just checked. The designers export it from ProE. Process-wise, it is more practical if the colleague who ultimately processes the dwg has this in hand herself. Quote
Cad64 Posted July 14, 2023 Posted July 14, 2023 On 7/13/2023 at 6:53 AM, zeichner said: I would like to see a tool that is either free or only requires a one-time payment. I have already looked at QCAD as I use this myself, however, merging layers is not so straightforward. Maybe take a look at DWG Trueview. It's a free application from Autodesk that allows you to do basic operations on CAD files. The main download button seems to be broken but if you scroll down the page to the "previous versions" section you can download the 2023 version. https://www.autodesk.com/products/dwg-trueview/overview#previous-versions Another option would be ZWCAD. It's not free but you can purchase perpetual licenses. You can download the trial version here: https://www.zwsoft.com/product/zwcad Quote
zeichner Posted July 14, 2023 Author Posted July 14, 2023 Thanks a lot, I will have a look and tell how it goes. Quote
BIGAL Posted July 15, 2023 Posted July 15, 2023 Bricscad lite supports lisp so could be programmed to speed up process. Quote
zeichner Posted July 15, 2023 Author Posted July 15, 2023 On 7/15/2023 at 5:19 AM, BIGAL said: Bricscad lite supports lisp so could be programmed to speed up process. Thank you, I will have a look. Don't know anything about lisp ... is there a tool which supports Python? Quote
SLW210 Posted July 15, 2023 Posted July 15, 2023 AutoCAD uses Python with https://pypi.org/project/pyautocad/ Not sure about the other CAD packages. Most of what you desire can be done in ProE when making the file IIRC. You may want to look at https://librecad.org/ (Forked from QCAD) Maybe check, but it used Lua and maybe now Python. Quote
BIGAL Posted July 16, 2023 Posted July 16, 2023 Found this Using Python scripts - BricsCAD BIM | Centrum pomocy Bricsys Pretty sure have seen Python and plain Bricscad. IronPython for Bricscad (theswamp.org) Quote
