Dien nguyen Posted July 5, 2023 Posted July 5, 2023 I created a Lisp routine to generate a scale list, but when I tried to create a search to check if that scale list already exists in the drawing, I encountered an error. Where did I go wrong? Quote error: CS tỉ lệ đó:100 ; error: AutoCAD rejected function: invalid table function argument(s): "SCALES" "LA 1:100" (defun c:cs (/ usercmd userosm *error* mode dist tile tile-2 dm_redef txt) (progn (initget 1) (setq tile (getreal "\u+0074\u+1ec9 \u+006c\u+1ec7 \u+0111\u+00f3\u+003a") ) ) (setq tile-2 (if (< tile 1) (strcat "LA 1:"(rtos (* tile 1000))"m") (strcat "LA 1:" (rtos tile)))) (setq ten-tile (strcat "1:" (rtos tile))) (if (tblsearch "SCALES" tile-2) (prompt "\ntile-2 Exsiting Scale List.") (command "-SCALELISTEDIT" "ADD" tile-2 ten-tile "E") ) (princ)) Quote
Crank Posted July 18, 2023 Posted July 18, 2023 (edited) Scales are not tables, but they are stored in a dictionary: (defun GetScaleList (/ ScaleList ScaleListDict ScaleListEnts N MASSOC) (defun MASSOC (KEY ALIST / X NLIST) (foreach X ALIST (if (eq KEY (car X)) (setq NLIST (cons (cdr X) NLIST)) ) ) (reverse NLIST) ) (setq ScaleListDict (dictsearch (namedobjdict) "ACAD_SCALELIST") ScaleListEnts (MASSOC 350 ScaleListDict) ScaleList (list "") N 0 ) (repeat (length ScaleListEnts) (setq ScaleList (cons (cdr (assoc 300 (entget (nth N ScaleListEnts)))) ScaleList) N (1+ N) ) ) (setq ScaleList (cdr (reverse ScaleList))) ) But you don't have to check if the scale already exists. You can recreate the scale if needed. Here is what I use: (defun c:1:1 ()(MaakSchaal 1)) (defun c:1:2 ()(MaakSchaal 2)) (defun c:1:5 ()(MaakSchaal 5)) (defun c:1:10 ()(MaakSchaal 10)) (defun c:1:20 ()(MaakSchaal 20)) (defun c:1:50 ()(MaakSchaal 50)) (defun c:1:100 ()(MaakSchaal 100)) (defun c:1:200 ()(MaakSchaal 200)) (defun c:1:500 ()(MaakSchaal 500)) (defun c:1:1000 ()(MaakSchaal 1000)) (defun c:1:2000 ()(MaakSchaal 2000)) (defun c:1:5000 ()(MaakSchaal 5000)) (defun c:1:10000 ()(MaakSchaal 10000)) (defun MaakSchaal (waarde / e schaal) (command ".undo" "be") (setq schaal (strcat "1:" (itoa waarde))) (setq e (getvar "EXPERT"))(setvar "EXPERT" 5) (command ".-scalelistedit" "A" schaal schaal "Exit") (setvar "EXPERT" e) (if (inPspace) (princ (strcat "\n" schaal " is added to the scalelist.")) ; else (setvar "CANNOSCALE" schaal) ) (command ".undo" "end") (princ) ) (defun inPSPACE ()(and (zerop (getvar "TILEMODE"))(zerop (getvar "VPMAXIMIZEDSTATE"))(eq (getvar "CVPORT") 1))) Edited July 18, 2023 by Crank Code tags 1 Quote
