Modify dimension text
RepCad
Hello everyone,
I'm trying to change the text of a aligned dimension with this function :  (real text is "106")
(vlax-put dimobj 'Measurement 15)
This error is returned
; error: Invalid number of parameters
I got the parameter from this dimension properties :
Select object: ; IAcadDimAligned: AutoCAD Aligned Dimension Interface
; Property values:
;   AltRoundDistance = 0.0
;   AltSubUnitsFactor = 100.0
;   AltSubUnitsSuffix = ""
;   AltSuppressLeadingZeros = 0
;   AltSuppressTrailingZeros = 0
;   AltSuppressZeroFeet = -1
;   AltSuppressZeroInches = -1
;   AltTextPrefix = ""
;   AltTextSuffix = ""
;   AltTolerancePrecision = 2
;   AltToleranceSuppressLeadingZeros = 0
;   AltToleranceSuppressTrailingZeros = 0
;   AltToleranceSuppressZeroFeet = -1
;   AltToleranceSuppressZeroInches = -1
;   AltUnits = 0
;   AltUnitsFormat = 2
;   AltUnitsPrecision = 2
;   AltUnitsScale = 25.4
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff681bb5e50>
;   Arrowhead1Block = ""
;   Arrowhead1Type = 0
;   Arrowhead2Block = ""
;   Arrowhead2Type = 0
;   ArrowheadSize = 20.0
;   DecimalSeparator = "."
;   DimConstrDesc = Exception occurred
;   DimConstrExpression = Exception occurred
;   DimConstrForm = 0
;   DimConstrName = Exception occurred
;   DimConstrReference = 0
;   DimConstrValue = Exception occurred
;   DimensionLineColor = 256
;   DimensionLineExtend = 0.0
;   DimensionLinetype = "ByLayer"
;   DimensionLineWeight = -1
;   DimLine1Suppress = 0
;   DimLine2Suppress = 0
;   DimLineInside = 0
;   DimTxtDirection = 0
;   Document (RO) = #<VLA-OBJECT IAcadDocument 000002d38cf026e8>
;   EntityTransparency = "0"
;   ExtensionLineColor = 256
;   ExtensionLineExtend = 0.18
;   ExtensionLineOffset = 0.0
;   ExtensionLineWeight = -1
;   ExtLine1Linetype = "ByLayer"
;   ExtLine1Point = (367365.0 198795.0 0.0)
;   ExtLine1Suppress = 0
;   ExtLine2Linetype = "ByLayer"
;   ExtLine2Point = (367365.0 198901.0 0.0)
;   ExtLine2Suppress = 0
;   ExtLineFixedLen = 75.0
;   ExtLineFixedLenSuppress = 0
;   Fit = 3
;   ForceLineInside = 0
;   FractionFormat = 0
;   Handle (RO) = "21123E"
;   HasExtensionDictionary (RO) = 0
;   HorizontalTextPosition = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000002d3fbc984b8>
;   Layer = "Dimension"
;   LinearScaleFactor = 1.0
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -2
;   Material = "ByLayer"
;   Measurement (RO) = 106.0
;   Normal = (0.0 0.0 1.0)
;   ObjectID (RO) = 78
;   ObjectName (RO) = "AcDbAlignedDimension"
;   OwnerID (RO) = 75
;   PlotStyleName = "Color_4"
;   PrimaryUnitsPrecision = 2
;   Rotation = 0.0
;   RoundDistance = 0.0
;   ScaleFactor = 1.0
;   StyleName = "tashfa-99"
;   SubUnitsFactor = 100.0
;   SubUnitsSuffix = ""
;   SuppressLeadingZeros = -1
;   SuppressTrailingZeros = -1
;   SuppressZeroFeet = -1
;   SuppressZeroInches = -1
;   TextColor = 256
;   TextFill = 0
;   TextFillColor = 0
;   TextGap = 0.09
;   TextHeight = 35.0
;   TextInside = -1
;   TextInsideAlign = 0
;   TextMovement = 0
;   TextOutsideAlign = -1
;   TextOverride = ""
;   TextPosition = (367292.0 198848.0 0.0)
;   TextPrefix = ""
;   TextRotation = 0.0
;   TextStyle = "ARIAL"
;   TextSuffix = ""
;   ToleranceDisplay = 0
;   ToleranceHeightScale = 1.0
;   ToleranceJustification = 1
;   ToleranceLowerLimit = 0.0
;   TolerancePrecision = 0
;   ToleranceSuppressLeadingZeros = 0
;   ToleranceSuppressTrailingZeros = 0
;   ToleranceSuppressZeroFeet = -1
;   ToleranceSuppressZeroInches = -1
;   ToleranceUpperLimit = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 000002d3fbc95990>
;   UnitsFormat = 2
;   VerticalTextPosition = 0
;   Visible = -1
Edited by RepCad
@RepCad  as expressed at the vlax-dump
Quote
It is Read Only.
you have to use TEXTOVERRIDE property
(SETQ DIM (CAR (ENTSEL)))
(SETQ DIM-OB (VLAX-ENAME->VLA-OBJECT DIM))
(VLA-PUT-TEXTOVERRIDE DIM-OB 15); just to change
(VLA-PUT-TEXTOVERRIDE DIM-OB "<>  15" ) ;show the real measurement and new override
Edited by devitg
add code
  • Like 2
Don't make this a habit @RepCad and have a note on the drawing maybe on defpoints so at least if someone comes back to edit the drawing they know some dimensions have text override.
