RepCad Posted June 24, 2023 Share Posted June 24, 2023 (edited) Hello everyone, I'm trying to change the text of a aligned dimension with this function : (real text is "106") (vlax-put dimobj 'Measurement 15) This error is returned : ; error: Invalid number of parameters I got the parameter from this dimension properties : Select object: ; IAcadDimAligned: AutoCAD Aligned Dimension Interface ; Property values: ; AltRoundDistance = 0.0 ; AltSubUnitsFactor = 100.0 ; AltSubUnitsSuffix = "" ; AltSuppressLeadingZeros = 0 ; AltSuppressTrailingZeros = 0 ; AltSuppressZeroFeet = -1 ; AltSuppressZeroInches = -1 ; AltTextPrefix = "" ; AltTextSuffix = "" ; AltTolerancePrecision = 2 ; AltToleranceSuppressLeadingZeros = 0 ; AltToleranceSuppressTrailingZeros = 0 ; AltToleranceSuppressZeroFeet = -1 ; AltToleranceSuppressZeroInches = -1 ; AltUnits = 0 ; AltUnitsFormat = 2 ; AltUnitsPrecision = 2 ; AltUnitsScale = 25.4 ; Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff681bb5e50> ; Arrowhead1Block = "" ; Arrowhead1Type = 0 ; Arrowhead2Block = "" ; Arrowhead2Type = 0 ; ArrowheadSize = 20.0 ; DecimalSeparator = "." ; DimConstrDesc = Exception occurred ; DimConstrExpression = Exception occurred ; DimConstrForm = 0 ; DimConstrName = Exception occurred ; DimConstrReference = 0 ; DimConstrValue = Exception occurred ; DimensionLineColor = 256 ; DimensionLineExtend = 0.0 ; DimensionLinetype = "ByLayer" ; DimensionLineWeight = -1 ; DimLine1Suppress = 0 ; DimLine2Suppress = 0 ; DimLineInside = 0 ; DimTxtDirection = 0 ; Document (RO) = #<VLA-OBJECT IAcadDocument 000002d38cf026e8> ; EntityTransparency = "0" ; ExtensionLineColor = 256 ; ExtensionLineExtend = 0.18 ; ExtensionLineOffset = 0.0 ; ExtensionLineWeight = -1 ; ExtLine1Linetype = "ByLayer" ; ExtLine1Point = (367365.0 198795.0 0.0) ; ExtLine1Suppress = 0 ; ExtLine2Linetype = "ByLayer" ; ExtLine2Point = (367365.0 198901.0 0.0) ; ExtLine2Suppress = 0 ; ExtLineFixedLen = 75.0 ; ExtLineFixedLenSuppress = 0 ; Fit = 3 ; ForceLineInside = 0 ; FractionFormat = 0 ; Handle (RO) = "21123E" ; HasExtensionDictionary (RO) = 0 ; HorizontalTextPosition = 0 ; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000002d3fbc984b8> ; Layer = "Dimension" ; LinearScaleFactor = 1.0 ; Linetype = "ByLayer" ; LinetypeScale = 1.0 ; Lineweight = -2 ; Material = "ByLayer" ; Measurement (RO) = 106.0 ; Normal = (0.0 0.0 1.0) ; ObjectID (RO) = 78 ; ObjectName (RO) = "AcDbAlignedDimension" ; OwnerID (RO) = 75 ; PlotStyleName = "Color_4" ; PrimaryUnitsPrecision = 2 ; Rotation = 0.0 ; RoundDistance = 0.0 ; ScaleFactor = 1.0 ; StyleName = "tashfa-99" ; SubUnitsFactor = 100.0 ; SubUnitsSuffix = "" ; SuppressLeadingZeros = -1 ; SuppressTrailingZeros = -1 ; SuppressZeroFeet = -1 ; SuppressZeroInches = -1 ; TextColor = 256 ; TextFill = 0 ; TextFillColor = 0 ; TextGap = 0.09 ; TextHeight = 35.0 ; TextInside = -1 ; TextInsideAlign = 0 ; TextMovement = 0 ; TextOutsideAlign = -1 ; TextOverride = "" ; TextPosition = (367292.0 198848.0 0.0) ; TextPrefix = "" ; TextRotation = 0.0 ; TextStyle = "ARIAL" ; TextSuffix = "" ; ToleranceDisplay = 0 ; ToleranceHeightScale = 1.0 ; ToleranceJustification = 1 ; ToleranceLowerLimit = 0.0 ; TolerancePrecision = 0 ; ToleranceSuppressLeadingZeros = 0 ; ToleranceSuppressTrailingZeros = 0 ; ToleranceSuppressZeroFeet = -1 ; ToleranceSuppressZeroInches = -1 ; ToleranceUpperLimit = 0.0 ; TrueColor = #<VLA-OBJECT IAcadAcCmColor 000002d3fbc95990> ; UnitsFormat = 2 ; VerticalTextPosition = 0 ; Visible = -1 Edited June 24, 2023 by RepCad Quote Link to comment Share on other sites More sharing options...
devitg Posted June 24, 2023 Share Posted June 24, 2023 @RepCad Would you, please, upload both dwg and lsp ? Quote Link to comment Share on other sites More sharing options...
devitg Posted June 24, 2023 Share Posted June 24, 2023 (edited) @RepCad as expressed at the vlax-dump Quote Measurement (RO) = 106.0 It is Read Only. you have to use TEXTOVERRIDE property (SETQ DIM (CAR (ENTSEL))) (SETQ DIM-OB (VLAX-ENAME->VLA-OBJECT DIM)) (VLA-PUT-TEXTOVERRIDE DIM-OB 15); just to change (VLA-PUT-TEXTOVERRIDE DIM-OB "<> 15" ) ;show the real measurement and new override Edited June 24, 2023 by devitg add code 2 Quote Link to comment Share on other sites More sharing options...
RepCad Posted June 24, 2023 Author Share Posted June 24, 2023 Great, thank you so much. Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 24, 2023 Share Posted June 24, 2023 Don't make this a habit @RepCad and have a note on the drawing maybe on defpoints so at least if someone comes back to edit the drawing they know some dimensions have text override. Quote Link to comment Share on other sites More sharing options...
