3dwannab Posted June 23, 2023 Share Posted June 23, 2023 (edited) Hi all, This has probably had numerous programs written for it but see the drawing file of what I was hoping to do. Can't for the life of me find one that suits my needs. The horizontal line is the section I require. The other lines are 3d Polylines with z values. I was looking for a lisp to do a section through the horizontal line of the crossing 3d polylines. Example.dwg Edited June 23, 2023 by 3dwannab Quote Link to comment Share on other sites More sharing options...
Steven P Posted June 23, 2023 Share Posted June 23, 2023 Sorry, in this case I have one that would work but can't send it out.... I think BIgAl has a link for paid for software - quite cheap by all accounts - that will do this (cheap: cost you less to buy it than develop a LISP I think). Alternatively you could look for 'Long Sections' online, see if there is anything suitable out there? Quote Link to comment Share on other sites More sharing options...
3dwannab Posted June 23, 2023 Author Share Posted June 23, 2023 Thanks for the info @Steven P. I've found this routine that spits out points at apparent intersections. I can then try adding drawing a polyline using the z values of the points this routine gathers. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/creating-points-at-3d-polyline-intersections/m-p/9692929#M403477 1 Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted June 23, 2023 Share Posted June 23, 2023 Just from curiosity : why do you have contours as 3DPOLY(s), when contours should be LWPOLYLINE(s) at different elevations... Quote Link to comment Share on other sites More sharing options...
3dwannab Posted June 23, 2023 Author Share Posted June 23, 2023 (edited) Hi Marko. No the road lines, ditches, footpaths and other features are all topo surveyed and they are as 3d polys. The cross-section is to get the profile across a road. I'm working on (trying) to get this done atm. A LWPOLYLINE. Can it have different Z values for its verts? What I'm trying to do is draw a line connecting the apparent intersections and then rotate it on the z-axis to appear correct in the top view. Edited June 23, 2023 by 3dwannab Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted June 23, 2023 Share Posted June 23, 2023 I told you what contours are - LWPOLYLINE, or SPLINE as isohypses with unique Z elevation... Each one have unique one all the length it spreads along terrain... Anyway, you could try (ssget "_F") - fence option and collect points of interes after which you just connect them with 3DPOLY command... But what I've found during my testings, fence option may be quirky depending of CAD you are using... BricsCAD was better than AutoCAD IMHO and in my past experiences... Quote Link to comment Share on other sites More sharing options...
Tsuky Posted June 23, 2023 Share Posted June 23, 2023 @3dwannab What I can offer you... I tried with your drawing and it seems to work. Initially my COUPE_TN routine only works with 3Dfaces from a natural terrain mesh. So I made 3Faces with your 3Dpoly (to see if it worked) with the 3dpolTO3dface routine I exploded your cut polyline to just get a line Then routine COUPE_TN is launched, I select your line representing the line of cut. The profile number is then requested, then the scale of the cut (the default value of 100 is very suitable for your example) The curvilinear abscissa of the profile is requested. And there; the TN section is drawn with the dimensions of distance and altitude. The axis is supposed to be the midpoint of the initially selected line. These routines are in French but should work anyway. Is this a good start for you? 3dpolTO3dface.lsp coupe_tn.lsp 1 Quote Link to comment Share on other sites More sharing options...
3dwannab Posted June 23, 2023 Author Share Posted June 23, 2023 (edited) Here's what I have so far. Thanks @Tsuky for the programs but I was trying to avoid creating surfaces. Don't mind the points, they're just placeholders for now Edited June 23, 2023 by 3dwannab Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 23, 2023 Share Posted June 23, 2023 The correct answer is get some civil software, like CIV3D or Civil Site Design, others out there, your trying to do civil road design on the cheap. To quote you "features are all topo surveyed" that is it what civil software is designed to do take field data and process it. To take a field survey from a total station make a strung plan, create a surface, create an alignment and produce cross sections can be as quick as say 10 minutes, plus it makes all the layouts ready for plotting. I had 12 streets in a grid, result 88 sheets. What a nightmare to try and do something from just 3D strings. Quote Link to comment Share on other sites More sharing options...
3dwannab Posted June 24, 2023 Author Share Posted June 24, 2023 External company does the topo and hands it off to us. We're mainly an architectural company and dabble in minor upgrades to roads. Add cycle lanes etc. Quote Link to comment Share on other sites More sharing options...
drdownload18 Posted June 24, 2023 Share Posted June 24, 2023 (edited) Look at modification by Lee Mac of the code by David Bethel found here: http://www.cadtutor.net/forum/showthread.php?62556-3D-polyline-Intersection&p=426585&viewfull=1#post426585 P.S. It's very useful to have points on Section for later edit. Edited June 24, 2023 by drdownload18 2 Quote Link to comment Share on other sites More sharing options...
3dwannab Posted June 25, 2023 Author Share Posted June 25, 2023 (edited) Thanks for the link @drdownload18 but David's code hung my ACAD. I found a fn to use a trim method and get the apparent intersection that way. The benefit at least for my limited knowledge is that it will work for lines, 2d polylines and 3d polylines too. Here's the GIF and code. Thanks to Kh.mbkh for the trim intersection function which I've shoehorned into this. I sorted the points by x values to draw them correctly. As always, not pretty code but best I can do. (vl-load-com) ;; -------------------------=={ Section_Profile }==--------------------------- ;; ----------------------------------------------------------------------- ;; AUTHOR & ADDITIONAL CODE ;; Author 3dwannab, 2023 ;; Thanks to Kh.mbkhs' for the apparent intersection code found at the link below: ;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/projected-intersection-between-a-line-and-3dPolyline/m-p/9435434#M398330 ;; ABOUT / NOTES ;; - Takes lines, 2d Poylines and 3d Polylines and allows the user to select a ;; section line to create a profile in 2d. ;; - This profile will get the Z value of the intersection and create a polyline ;; profile. And 3d rotate it and move it to where the Z value is now the Y value. ;; So a point 100,1000,333 will be now 100,333,0. ;; - Points are also created at this location, that match that of the profile ;; lines. This means they are easily identifiable, should you have them in ;; layers. ;; FUNCTION SYNTAX ;; Short-cut SECP ;; Long-cut Section_Profile ;; VERSION DATE INFO ;; Version 1.0 2023.06.25 Initial ;; TO-DO LIST ;; - Try to fix bugs below. ;; BUGS ;; (command "_.matchprop" ...) Outputs to the commandline even though cmdecho is 0. ;; (command "_.rotate3d" ...) Outputs to the commandline even though cmdecho is 0. ;; ----------------------------------------------------------------------- ;; -------------------=={ Section_Profile START }==----------------------- (defun c:SECP () (C:Section_Profile)) (defun C:Section_Profile (/ *error* 3dPolObj acDoc basept idx lastEnt lstPts newPos pfpline proLines ptFinal ptInterSec secLine ssSel var_angbase var_angdir var_cmdecho var_peditaccept) (defun *error* (errmsg) (and acDoc (vla-EndUndoMark acDoc)) (and errmsg (not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " errmsg " >>\n")) ) (setvar 'cmdecho var_cmdecho) (setvar 'peditaccept var_peditaccept) (setvar 'angbase var_angbase) (setvar 'angdir var_angdir) (princ) ) (setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object))) (or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc)) (setq var_angbase (getvar 'angbase)) (setq var_angdir (getvar 'angdir)) (setq var_cmdecho (getvar 'cmdecho)) (setq var_peditaccept (getvar 'peditaccept)) (setvar 'angbase 0) (setvar 'angdir 0) (setvar 'cmdecho 0) (setvar 'peditaccept 1) if (and (setq secLine (car (entsel "\nSelect Section Line (Line or Polyline)..."))) (princ "\nSelect Lines or Polylines (2D or 3D)...") (setq proLines (ssget '((0 . "LINE,*POLYLINE")))) ) (progn (repeat (setq idx (sslength proLines)) (setq idx (1- idx) ent (ssname proLines idx) ) ;; Code to get the apparent intersection of the section line and profile line (setq ptFinal (vlax-curve-getEndPoint secLine)) ; end point of the pline (command "_trim" ent "" ptFinal "") (setq 3dPolObj (vlax-ename->vla-object ent)) (setq pfpline (vlax-curve-getEndPoint secLine)) (setq ptInterSec (vlax-curve-getclosestpointtoprojection 3dPolObj pfpline '(0 0 1))) (command "_.point" ptInterSec) (command "_.matchprop" "_non" ent "_non" (entlast) "") (setq newPos (list (car ptInterSec) (caddr ptInterSec) 0)) (command "_.move" (entlast) "" "_NONE" ptInterSec "_NONE" newPos) (setq lstPts (cons ptInterSec lstPts)) ) ) (if lstPts (progn ;; Sort the list by the X value. Means the lines are drawn correctly along the X axis (setq lstPts (vl-sort lstPts '(lambda (x y) (if (= (car x) (car y)) (< (cadr x) (cadr y)) (< (car x) (car y)))))) ; Get the last entity created. This helps to get the newly created objects (setq lastEnt (entlast)) ;; Draw the lines (if (> (length lstPts) 1) (mapcar '(lambda (a b) (entmakex (list '(0 . "line") (cons 10 a) (cons 11 b)))) lstPts (cdr lstPts)) ) ;; Select all entities created in function code above (setq ssSel (ssadd)) (while (setq lastEnt (entnext lastEnt)) (ssadd lastEnt ssSel) ) ;; Rotate the selection so it appears correct in the top view (command "_.rotate3d" ssSel "" "_X" (car lstPts) "270") ;; Sample of the lstPts variable (For testing) ;; (setq lstPts '((-11246.5 34919.5 550.0) (-8782.5 34919.5 150.0) (-6782.5 34919.5 150.0) (-6716.0 34919.5 0.05) (-3716.0 34919.5 100.0) (-716.0 34919.5 0.05) (-649.5 34919.5 150.0) (1350.5 34919.5 150.0) (3814.5 34919.5 550.0))) ;; Set basePt and newPos. Sets the new profile from its Z values to according Y values. (setq basept (car lstPts)) (setq newPos (list (car basept) (caddr basept) 0)) (command "_.move" ssSel "" "_NONE" basept "_NONE" newPos) ;; Flatten the new objects for good measure (vl-cmdf "move" ssSel "" "0,0,0" "0,0,1e99") (vl-cmdf "move" ssSel "" "0,0,0" "0,0,-1e99") ;; Join the new profile lines together to create a polyline (command "_.pedit" "_M" ssSel "" "_J" "" "") ; (command "_.zoom" "_o" (ssget "_L") "") ;; Optional to zoom to created objects (sssetfirst nil (ssget "_L")) (princ "\nA profile has been created and selected.. Message me if problemo. Signed: 3dwannab.") (princ) ) ) (vla-EndUndoMark acDoc) (*error* nil) ) ;; end Section_Profile (princ "\n: ------------------------------\n\"3dwannab_Section_Profile.lsp\" locked and loaded | Version 1.0 by 3dwannab. Type \"Section_Profile\" OR \"SECP\" to run.\n: ------------------------------\n") (princ) ;; ----------------------------------------------------------------------- ;; ------------------=={ Section_Profile END }==-------------------------- ;; EOL ;;(C:Section_Profile) ;; Unblock for testing in VSCode Road Profile 3d Polys, 2d Polys And Lines.dwg Edited June 25, 2023 by 3dwannab Added sample drawing 1 Quote Link to comment Share on other sites More sharing options...
Tsuky Posted June 26, 2023 Share Posted June 26, 2023 Here's what I have so far. Thanks @Tsuky for the programs but I was trying to avoid creating surfaces. Hi, I adapted the previous lisp (trying to translate it as well as possible) to work with curvilinear entities. The command is CROSS_SECT. It only accepts a line to define the section (explode if polyline) As before it will ask you to select the section (as a line, considering that the middle of the line will represent the axis of the section) Answer the questions The section will be draw and you will have the choice to accept it or not. Following this another command called: SELECT_PROFILE is available It allows to redisplay a defined section and to change scale for the representation if you update the profile. In addition, you can draw other polylines on this section by forcing the colors to 1 4 5 or 6. If those are drawn then a new call to SELECT_PROFILE with an update will automatically dimension those polylines into a completed title block. cross_sect.lsp 1 Quote Link to comment Share on other sites More sharing options...
3dwannab Posted June 27, 2023 Author Share Posted June 27, 2023 Cool @Tsuky. Thanks very much. I was wanting to work on this yesterday evening but didn't get a chance. I noticed mine was a little buggy but this is some nice learning material I'll try to get mine working properly in the meantime. Thanks again. Quote Link to comment Share on other sites More sharing options...
drdownload18 Posted July 7, 2023 Share Posted July 7, 2023 On 6/27/2023 at 12:50 PM, 3dwannab said: Cool @Tsuky. Thanks very much. I was wanting to work on this yesterday evening but didn't get a chance. I noticed mine was a little buggy but this is some nice learning material I'll try to get mine working properly in the meantime. Thanks again. Your Lisp will be excellent. Please share it with us once you enhance it. You can add lisp to annotate cross section elevations like this: (defun c:ypt ( / i p s ) (if (setq s (ssget '((0 . "POINT")))) (repeat (setq i (sslength s)) (setq p (assoc 10 (entget (ssname s (setq i (1- i)))))) (entmake (list '(000 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") (cons 1 (strcat (rtos (caddr p)))) p ) ) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
3dwannab Posted July 22, 2023 Author Share Posted July 22, 2023 There's really no need to. This'll do it a lot better than I ever would. Use the Profile 3D Polyline command in CadTools. My script will need to be modified to create a 3d polyline and not rotate it. Then this tool can do what you want. If I ever need this again I will modify my program to create 3d polys and then use this afterwards. The program is defiantly something you should have in your toolbox. https://www.glamsen.se/CadTools.htm 1 Quote Link to comment Share on other sites More sharing options...
aridzv Posted July 24, 2023 Share Posted July 24, 2023 (edited) @3dwannab Hi. here is a lisp that do the same as Profile 3D Polyline command, that for me works better... aridzv. long_section_3dp.lsp Edited July 24, 2023 by aridzv 1 Quote Link to comment Share on other sites More sharing options...
3dwannab Posted July 25, 2023 Author Share Posted July 25, 2023 13 hours ago, aridzv said: @3dwannab Hi. here is a lisp that do the same as Profile 3D Polyline command Really needs undo marks given the number of line commands there is. Quote Link to comment Share on other sites More sharing options...
