basty Posted June 22, 2023 Share Posted June 22, 2023 Can someone tell me please what is meant by "maximum arc condition" and how to use it in acad? Please show me easy example also. Thanks 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 22, 2023 Share Posted June 22, 2023 A arc between 2 lines will fail if the start or end points exceed the start or end points of either line. I think that is what your talking about. You can use the end points and work out a maximum radius its a formula so a lisp would be used. Quote Link to comment Share on other sites More sharing options...
