Can someone tell me please what is meant by "maximum arc condition" and how to use it in acad?
Please show me easy example also.
Thanks
A arc between 2 lines will fail if the start or end points exceed the start or end points of either line. I think that is what your talking about.
You can use the end points and work out a maximum radius its a formula so a lisp would be used.
