Eng.minamaged Posted June 20, 2023 Posted June 20, 2023 Lisp, to trim lines and add add lines for gaps for specific layers RC, PC and trim/join separate layer for PC, and for RC test.dwgFetching info... Quote
marko_ribar Posted June 20, 2023 Posted June 20, 2023 (edited) Your drawing is real mess... Recently I wrote something based on separated lines, but only for forming closed rectangular lwpolyline... With your DWG, it's not going to work; you have to do the job manually... For interes, here is the link of my *.lsp, but like I stated, it's just for that single case - there should be no trimmed collinear segments... One more thing that can help you : JOIN command have ability to connect collinear parts into single line... https://www.theswamp.org/index.php?topic=58344.msg614957#msg614957 Edited June 20, 2023 by marko_ribar 1 Quote
