land Posted June 18, 2023 Share Posted June 18, 2023 Hello everyone, I need help to make these lines by a lisp by one . Quote Link to comment Share on other sites More sharing options...
Steven P Posted June 18, 2023 Share Posted June 18, 2023 You could look at finding out the end points and centre of the arc, something like this: should put a point at the start point, end point and centre of an arc. ;;https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/put-a-point-at-each-end-of-an-arc/td-p/3268078 (defun c:test (/ ss i data ctr rad) (if (setq ss (ssget '((0 . "ARC")))) (repeat (setq i (sslength ss)) (setq data (entget (ssname ss (setq i (1- i)))) ctr (cdr (assoc 10 data)) rad (cdr (assoc 40 data)) ) (entmake (list '(0 . "POINT") (cons 10 (polar ctr (cdr (assoc 50 data)) rad)))) ; end a (entmake (list '(0 . "POINT") (cons 10 (polar ctr (cdr (assoc 51 data)) rad)))) ; end b (entmake (list '(0 . "POINT") (assoc 10 data))) ; arc midpoint ) ) (princ) ) Change the entmake lines so that it won't create points Something like this will get the midpoint of 2 points: ;;https://www.cadtutor.net/forum/topic/2146-midpoint-between-two-points/ ;; Returns the middle of two points (defun mid-pt (p1 p2) (polar p1 (angle p1 p2) (/ (distance p1 p2) 2.) ) ) and of course the 2 end points can be found using the first example (polar ctr (cdr (assoc 50 data)) rad)) then you can just draw a line however you like between this midpoint and the arc midpoint (variable ctr from the first example) Quote Link to comment Share on other sites More sharing options...
Isaac26a Posted June 18, 2023 Share Posted June 18, 2023 Not sure but maybe this can help 1 Quote Link to comment Share on other sites More sharing options...
land Posted June 18, 2023 Author Share Posted June 18, 2023 thank you for this lisp but i need to select all acrs by one time Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 18, 2023 Share Posted June 18, 2023 13 minutes ago, land said: thank you for this lisp but i need to select all acrs by one time Upload your drawing to take a close look. 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted June 18, 2023 Share Posted June 18, 2023 Have a look at what I posted, the information should all be there - but you might need to do some thinking to make it work - which is of course a great way to learn...... I think though the mid point I gave above is the centre of the arc and not the middle of the line, This will be better if you can work out how to put it all together: (defun objectMidpoint (MyEnt / ) ; MyEnt is entity name from say (ssname n) function (setq object (vlax-ename->vla-object (car (Entsel)))) ;;https://www.thecadforums.com/threads/find-the-midpoint-of-an-arc.29507/ ;;(defun objectMidpoint (object) (vlax-curve-getpointatparam object (/ (+ (vlax-curve-getstartparam object) (vlax-curve-getendparam object) ) 2.0 ) ) ) Quote Link to comment Share on other sites More sharing options...
Isaac26a Posted June 18, 2023 Share Posted June 18, 2023 As long as all the entities are Arcs this will work ;;; c2mpts Line from Midpoint of chords to Midpoint of arcs ;;; 20230618 Isaac A. ;;; https://www.cadtutor.net/forum/topic/77751-lisp-for-mid-line-for-arcs-automatically/ (vl-load-com) (defun c:c2mpts (/ a b c ct d e oe l oo s ve) (setq oe (getvar 'cmdecho) oo (getvar 'osmode) ) (setvar 'cmdecho 0) (vl-cmdf "_.undo" "_begin") (setvar 'osmode 37) (princ "\nProgram to create a line from midpoint of chord to midpoint of an arc ") (princ "\nSelect the arc elements") (setq s (ssget ":L" '((0 . "ARC") ))) (setq ct 0 l (sslength s)) (while (< ct l) (setq e (cdar (entget (ssname s ct))) ve (vlax-ename->vla-object e) a (vlax-curve-getStartPoint ve) b (vlax-curve-getEndPoint ve) c (ia:midp a b) d (if (= (cdr (assoc 0 (entget e))) "ARC") (vlax-curve-getPointAtDist ve (* 0.5 (vla-get-ArcLength ve))) (vlax-curve-getPointAtDist ve (* 0.5 (vla-get-length ve))) ) ) (vl-cmdf "_.line" "_non" c "_non" d "") (setq ct (1+ ct)) ) (setvar 'osmode oo) (setvar 'cmdecho oe) (vl-cmdf "_.undo" "_end") (princ "\n") (princ) ) ;;; ia:midp ;;; Returns the midpoint of 2 given points (defun ia:midp (a b) (mapcar '* (mapcar '+ a b) '(0.5 0.5 0.5)) ) Quote Link to comment Share on other sites More sharing options...
Tsuky Posted June 18, 2023 Share Posted June 18, 2023 This for bulge of Lwpolyline or arc? (vl-load-com) (defun make_line (dxf / lst_dxf) (setq lst_dxf (list (cons 0 "LINE") (cons 100 "AcDbEntity") (assoc 67 dxf) (assoc 410 dxf) (cons 8 (getvar "CLAYER")) (cons 100 "AcDbLine") (cons 10 pt_mid) (cons 11 pt_mid-vtx) (assoc 210 dxf) ) ) (foreach n '(6 39 48 62 370 420) (if (assoc n dxf) (setq lst_dxf (append lst_dxf (list (assoc n dxf)))) ) ) (entmake lst_dxf) ) (defun c:arrow ( / ss n ename obj dxf_ent dxf_210 pr seg_bulge pt_first pt_snd pt_mid-vtx pt_mid) (princ "\nSelect polylines or arcs ") (while (null (setq ss (ssget '((0 . "LWPOLYLINE,ARC")))))) (vla-StartUndoMark (vla-get-ActiveDocument (vlax-get-acad-object))) (repeat (setq n (sslength ss)) (setq ename (ssname ss (setq n (1- n))) obj (vlax-ename->vla-object ename) dxf_ent (entget ename) dxf_210 (cdr (assoc 210 dxf_ent)) pr -1 ) (cond ((eq (cdr (assoc 0 dxf_ent)) "ARC") (setq pt_mid-vtx (vlax-curve-getPointAtParam obj (* (+ (vlax-curve-getStartParam obj) (vlax-curve-getEndParam obj)) 0.5)) pt_mid (mapcar '* (mapcar '+ (vlax-curve-getStartPoint obj) (vlax-curve-getEndPoint obj)) '(0.5 0.5 0.5)) ) (make_line dxf_ent) ) (T (repeat (fix (vlax-curve-getEndParam ename)) (setq seg_bulge (vla-GetBulge obj (setq pr (1+ pr)))) (cond ((not (zerop seg_bulge)) (setq pt_first (trans (vlax-curve-GetPointAtParam ename pr) 0 dxf_210) pt_snd (trans (vlax-curve-GetPointAtParam ename (1+ pr)) 0 dxf_210) pt_mid-vtx (trans (vlax-curve-GetPointAtParam ename (+ 0.5 pr)) 0 dxf_210) pt_mid (mapcar '* (mapcar '+ pt_first pt_snd) '(0.5 0.5 0.5)) ) (make_line dxf_ent) ) ) ) ) ) ) (vla-EndUndoMark (vla-get-ActiveDocument (vlax-get-acad-object))) (prin1) ) 1 Quote Link to comment Share on other sites More sharing options...
land Posted June 19, 2023 Author Share Posted June 19, 2023 thats my file sample arcs.dwg Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 19, 2023 Share Posted June 19, 2023 Here you go, please try it and let me know. (defun c:Test (/ int sel ent ) ;;----------------------------------------------------;; ;; Author : Tharwat Al Choufi ;; ;; website: https://autolispprograms.wordpress.com ;; ;;----------------------------------------------------;; (and (princ "\nSelect arcs to create pivot lines to them : ") (setq int -1 sel (ssget '((0 . "ARC")))) (while (setq int (1+ int) ent (ssname sel int)) (entmake (list '(0 . "LINE") (cons 10 (vlax-curve-getpointatdist ent (/ (vlax-curve-getdistatpoint ent (vlax-curve-getendpoint ent)) 2.0))) (cons 11 (mapcar (function (lambda (j k) (/ (+ j k) 2.0))) (vlax-curve-getstartpoint ent) (vlax-curve-getendpoint ent) ) ) ) ) ) ) (princ) ) (vl-load-com) 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted June 19, 2023 Share Posted June 19, 2023 This example is using the examples I posted above as a basis (see references above for links): (defun c:test (/ ss i data ctr rad StartPr EndPt CtrPt object) (if (setq ss (ssget '((0 . "ARC")))) ; select only arcs (repeat (setq i (sslength ss)) ; repeat for each arc selected (setq data (entget (ssname ss (setq i (1- i)))) ; entity name ctr (cdr (assoc 10 data)) ; centre point of arc rad (cdr (assoc 40 data)) ; radius of arc StartPt (polar ctr (cdr (assoc 50 data)) rad)) ; start of arc line EndPt (polar ctr (cdr (assoc 51 data)) rad)) ; end of arc line CtrPt (mapcar '/ (mapcar '+ StartPt EndPt) '(2 2 2))) ; mid point of arc chord object (vlax-ename->vla-object (ssname ss i))) ; vla- object name of arc entity MidPt (vlax-curve-getpointatparam object (/ (+ (vlax-curve-getstartparam object) (vlax-curve-getendparam object) ) 2.0 ) )) ; mid point of arc curve ) ; end setq (command "line" MidPt CtrPt "") ; draw line ) ; end repeat ) ; end if (princ) ) Quote Link to comment Share on other sites More sharing options...
devitg Posted June 19, 2023 Share Posted June 19, 2023 7 hours ago, land said: thats my file sample arcs.dwg 86.88 kB · 4 downloads @land My way to skin the fish. arcs-chords+arrow.dwg make-arrows-@-arcs.LSP 1 Quote Link to comment Share on other sites More sharing options...
land Posted June 25, 2023 Author Share Posted June 25, 2023 Worked well thank you On 6/19/2023 at 10:59 AM, Tharwat said: (defun c:Test (/ int sel ent ) ;;----------------------------------------------------;; ;; Author : Tharwat Al Choufi ;; ;; website: https://autolispprograms.wordpress.com ;; ;;----------------------------------------------------;; (and (princ "\nSelect arcs to create pivot lines to them : ") (setq int -1 sel (ssget '((0 . "ARC")))) (while (setq int (1+ int) ent (ssname sel int)) (entmake (list '(0 . "LINE") (cons 10 (vlax-curve-getpointatdist ent (/ (vlax-curve-getdistatpoint ent (vlax-curve-getendpoint ent)) 2.0))) (cons 11 (mapcar (function (lambda (j k) (/ (+ j k) 2.0))) (vlax-curve-getstartpoint ent) (vlax-curve-getendpoint ent) ) ) ) ) ) ) (princ) ) (vl-load-com) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 25, 2023 Share Posted June 25, 2023 2 hours ago, land said: Worked well thank you Cool, you are welcome anytime. 1 Quote Link to comment Share on other sites More sharing options...
