How to Stretch or reduce Rectangles Based on two Polyline boundaries ?
Hello,
I have two polyline as Boundaries and a Rectangle . The case is that the rectangle length must not exceed the polyline Boundaries on both sides nor be less than those polyline Boundaries distance on both sides (ie Rectangle length = Two Boundaries Distance) . Is there any lisp through which it can be achieved ?
I believe using the stretch command would be faster and fewer step inputs than any custom program if the case is just like that.
Here, help yourself...
(defun c:polyboundrect ( / ss s1 s2 rect rectx b1 b2 x1 x2 pl p0 p1 p2 p3 )
  (prompt "\nSelect LWPOLYLINE or LINE BOUNDARIES and RECTANGLE LWPOLYLINE...")
  (if (setq ss (ssget "_:L" '((0 . "LWPOLYLINE,LINE"))))
      (sssetfirst nil ss)
      (setq s1 (ssget "_I" '((0 . "LWPOLYLINE") (-4 . "&=") (70 . 1) (90 . 4) (-4 . "<not") (-4 . "<>") (42 . 0.0) (-4 . "not>"))))
      (sssetfirst nil ss)
      (setq s2 (ssget "_I" '((-4 . "<or") (0 . "LINE") (-4 . "<and") (0 . "LWPOLYLINE") (-4 . "<not") (-4 . "&=") (70 . 1) (-4 . "not>") (90 . 2) (-4 . "<not") (-4 . "<>") (42 . 0.0) (-4 . "not>") (-4 . "and>") (-4 . "or>"))))
      (sssetfirst)
      (setq rect (ssname s1 0))
      (setq rectx (entget rect))
      (setq b1 (ssname s2 0))
      (setq b2 (ssname s2 1))
      (setq x1 (car (trans (cdr (assoc 10 (entget b1))) (if (= (cdr (assoc 0 (entget b1))) "LINE") 0 rect) 1)))
      (setq x2 (car (trans (cdr (assoc 10 (entget b2))) (if (= (cdr (assoc 0 (entget b2))) "LINE") 0 rect) 1)))
      (setq pl (mapcar '(lambda ( p ) (trans (list (car p) (cadr p) (cdr (assoc 38 rectx))) rect 1)) (mapcar 'cdr (vl-remove-if '(lambda ( x ) (/= (car x) 10)) rectx))))
      (setq p0 (car (vl-sort pl '(lambda ( a b ) (if (= (car a) (car b)) (< (cadr a) (cadr b)) (< (car a) (car b)))))))
      (setq p1 (car (vl-remove-if-not '(lambda ( x ) (= (cadr x) (cadr p0)) (> (car x) (car p0))) (vl-remove p0 pl))))
      (setq p2 (car (vl-remove-if-not '(lambda ( x ) (= (car x) (car p1)) (> (cadr x) (cadr p0))) (vl-remove p1 (vl-remove p0 pl)))))
      (setq p3 (car (vl-remove p2 (vl-remove p1 (vl-remove p0 pl)))))
      (if (< x1 x2)
          (setq p0 (trans (list x1 (cadr p0)) 1 rect))
          (setq p1 (trans (list x2 (cadr p1)) 1 rect))
          (setq p2 (trans (list x2 (cadr p2)) 1 rect))
          (setq p3 (trans (list x1 (cadr p3)) 1 rect))
          (setq p0 (trans (list x2 (cadr p0)) 1 rect))
          (setq p1 (trans (list x1 (cadr p1)) 1 rect))
          (setq p2 (trans (list x1 (cadr p2)) 1 rect))
          (setq p3 (trans (list x2 (cadr p3)) 1 rect))
      (setq rectx (append (reverse (member (assoc 39 rectx) (reverse rectx))) (list (cons 10 p0) (cons 10 p1) (cons 10 p2) (cons 10 p3)) (list (assoc 210 rectx))))
      (entupd (cdr (assoc -1 (entmod rectx))))
M.R.
Edited by marko_ribar
  • Like 2
  • 7 months later...
SUPER LISP
Would it be possible to extend a single segment to a single line, Segment, polyline or x-line???
By preserving the orientation of adjacent segments
Thank you in advance, I've been looking for several weeks
Edited by DELLA MAGGIORA YANN
For that why not just use EXTEND command...
it only works on rectangles
I would like this to work on polygons.
while preserving the orientation of adjacent segments
in the APLUS plugin there is a command in this style
a selection of the limit and then on the segment of the polygon to move.
segment will therefore be superimposed on the selected limit.
this also works on a limit projection
yes, that's right, you understood my problem.
but you will have the possibility of making your lisp work for only one side, that would not be bad. THANKS
On 1/21/2024 at 3:34 AM, DELLA MAGGIORA YANN said:
I wrote one using XDRX API. It should have more functions than your video. It can EXTEND multiple edges.
I don’t know how to post animations. For details, please see: https://www.theswamp.org/index.php?topic=59151.0
animations link,click to see:  http://www.theswamp.org/index.php?action=dlattach;topic=59151.0;attach=42200;image
(defun c:xdtb_polyextend (/ e1 e2 e3 inx1 inx2 bak)
  (if (and (setq e1 (xdrx-entsel (xdrx-string-multilanguage "\n拾取多段线延伸起始边<结束>:"
							    "\nPick Polyline Extend start Edge<Exit>:"
				 '((0 . "*polyline"))
	   (or (setq e2	(xdrx-entsel (xdrx-string-multilanguage	"\n拾取延伸结束边<alone>:"
								"\nPick Extend end Edge<Exit>:"
	       t
	   (equal (car e1) (car e2))
    (progn (xd::begin)
	   (setq inx1 (xdrx-getpropertyvalue (car e1) "onseg" (cadr e1))
		 inx2 inx1
	   (if e2
	     (setq inx2 (xdrx-getpropertyvalue (car e2) "onseg" (cadr e2)))
	   (if (setq e3	(xdrx-entsel (xdrx-string-multilanguage	"\n拾取目标边<退出>:"
								"\nPick Dest Edge<Exit>:"
				     '((0 . "*polyline,line,arc,circle"))
	     (progn (setq bak (xdrx-object-clone (car e1)))
		    (xdrx-polyline-extend inx1 inx2 e1 e3)
		    (xdrx-entity-matchprop bak (car e1))
		    (xdrx-entity-delete bak)
	   (xd::end)
Edited by XDSoft
thank's but don't works for
 i have bricscad 2024
i have a message error
; ----- LISP : Call Stack -----
; [0]...C:XDTB_POLYEXTEND <<--
; ----- Error around expression -----
; (XDRX-ENTSEL (XDRX-STRING-MULTILANGUAGE "
Choisissez une polyligne et prolongez le bord de début <fin>:" "
Pick Polyline Extend start Edge<Exit>:") '((0 . "*polyline")))
; in file :
; E:\MA CLE\reisntall - Copie\BRICSCAD YD 24\xdtb_polyextend.lsp
; error : no function definition <XDRX-ENTSEL> ; expected FUNCTION at [eval]
