mhy3sx Posted June 15, 2023 Posted June 15, 2023 Hi, I am trying to change the text height by the giving scale using a ht parameter , but I can not find In the code where the text height change. Can any one help (defun C:LabelContour ( / *error* @ang cmdecho Done Space E Ent Etype Flag Obj P OK Ang Elev Prec) ;* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * ;* * ;* LabelContour.LSP by John F. Uhden * ;* 2 Village Road * ;* Sea Girt, NJ 08750 * ;* * ;* * * * * * * * * * * * Do not delete this heading! * * * * * * * * * * * * ; Routine labels the elevation of 2D polylines and AECC_CONTOURS. ; v1.00 (02-13-08) on 5:13pm from Hoboken ; v1.01 (04-27-08) in Fun Room - added precision; fixed (atan...) ;-------------------I add this Lines --------------------------- (if (=(tblsearch "layer" "Contour Label") nil) (command "_layer" "_m" "Contour Label" "_c" "7" "" "") );end if (setvar "clayer" "Contour Label") ; (setq scl (getvar "useri1")) (setq scl (getint "\n Set Scale (50,100,200,250,500,etc) :")) (setq ht (* 0.00175 scl)) ;-------------------------------------------------------------- (gc) (vl-load-com) (prompt "\nLabelContour v1.01 (c)2008, John F. Uhden, Cadlantic") (defun *error* (error) (if (= (type cmdecho) 'INT)(setvar "cmdecho" cmdecho)) (vla-endundomark *doc*) (cond ((not error)) ((wcmatch (strcase error) "*QUIT*,*CANCEL*")) (1 (princ (strcat "\nERROR: " error))) ) (princ) ) ;;------------------------------------------- ;; Initialize drawing and program variables: ;; (or *acad* (setq *acad* (vlax-get-acad-object))) (or *doc* (setq *doc* (vla-get-ActiveDocument *acad*))) (vla-endundomark *doc*) (vla-startundomark *doc*) (setq cmdecho (getvar "cmdecho") Space (vlax-get *doc* (if (= (getvar "cvport") 1) 'PaperSpace 'ModelSpace)) ) (setvar "cmdecho" 0) (command "_.Expert" (getvar "expert")) ; dummy command (setvar "errno" 0) (defun @ang (ang) (if (<= (* 0.5 pi) ang (* 1.5 pi)) (+ ang pi) ang ) ) (or (setq Prec (vl-bb-ref 'CAD#LabelContourPrec)) (vl-bb-set 'CAD#LabelContourPrec (setq Prec 0)) ) (initget 4) ; no negative (while (not Done) (setq OK nil) (if (setq P (entsel "\nSelect contour at point to label: ")) (setq E (car P) P (cadr P) Ent (entget E) Obj (vlax-ename->vla-object E) Etype (cdr (assoc 0 Ent)) Flag (cdr (assoc 70 Ent)) ) (setq Ent nil) ) (cond ((= (getvar "errno") 52) (setq Done 1) ) ((not Ent)) ((= Etype "AECC_CONTOUR")(setq OK 1)) ((= Etype "LWPOLYLINE")(setq OK 1)) ((and (= Etype "POLYLINE")(= (logand Flag 8) 0))(setq OK 1)) (1 (prompt "\nEntity selected is not a contour or 2D polyline.")) ) (and OK (setq P (vlax-curve-getclosestpointto Obj P)) ;| BE CAREFUL WITH ATAN... Command: (apply 'atan (list -3.0 -5.0)) -2.60117 Command: (atan (apply '/ (list -3.0 -5.0))) 0.54042 |; (setq ang (atan (apply '/ (cdr (reverse (vlax-curve-getfirstderiv Obj (vlax-curve-getparamatpoint obj P))))))) (setq Elev (last P)) (setq Obj (vlax-invoke Space 'AddMtext P 0.0 (rtos Elev 2 2))) (or (vlax-put Obj 'AttachmentPoint 5) 1) ; Middle Center (or (vlax-put Obj 'InsertionPoint (list (car P)(cadr P) 0.0)) 1) (or (not (vlax-property-available-p Obj 'Backgroundfill)) (vlax-put Obj 'Backgroundfill 1) 1 ) (or (vlax-put Obj 'Rotation (@ang ang)) 1) ) ) (*error* nil) ) (defun c:LC ()(c:LabelContour)) Thanks Quote
Steven P Posted June 15, 2023 Posted June 15, 2023 This line creates the text: (setq Obj (vlax-invoke Space 'AddMtext P 0.0 (rtos Elev 2 2))) searching about on the internet should give you solution and explanation, Add something like this on the next line, where ht is your text height - might need to alter the position of the text height line to make it work (vla-put-textheight obj ht) Quote
mhupp Posted June 15, 2023 Posted June 15, 2023 (edited) Use to check properties of entity's in AutoCAD. ;;----------------------------------------------------------------------------;; ;; Dump All Visual Lisp Methods and Properties for Selected Entity (defun C:VDumpIt (/ ent) (while (setq ent (car (entsel "\nSelect Entity to Dump"))) (vlax-Dump-Object (vlax-Ename->Vla-Object ent) t) ) (princ) ) Most are simple to change as (val-put-"property name" vla-object value) Properties values listed with a (RO) are read only. Edited June 15, 2023 by mhupp 1 Quote
mhy3sx Posted June 16, 2023 Author Posted June 16, 2023 I can not understand how to use all this !!! Is any other easy way to use ht ? Thanks Quote
mhupp Posted June 19, 2023 Posted June 19, 2023 give this a look https://www.afralisp.net/archive/methods/lista/addtext_method.htm Quote
mhy3sx Posted June 19, 2023 Author Posted June 19, 2023 Hi mhupp. I add this line (vla-put-textheight obj ht) but i didn't see any difference , the text height didn't change Thanks Quote
Tharwat Posted June 19, 2023 Posted June 19, 2023 @mhy3sx Give this a shot and let me know. NOTE: Yo can press enter to accept the default scale factor or enter your desired one. (defun c:Test (/ *error* prc sel ent pos cls ang typ txt) ;;----------------------------------------------------;; ;; Author : Tharwat Al Choufi ;; ;; website: https://autolispprograms.wordpress.com ;; ;;----------------------------------------------------;; (defun *error* (msg) (and prc (setvar 'DIMZIN prc)) (vla-endundomark *TH:doc*) (and msg (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\nError => " msg)) ) (princ) ) (or *TH:doc* (setq *TH:doc* (vla-get-ActiveDocument (vlax-get-acad-object))) ) (vla-endundomark *TH:doc*) (vla-startundomark *TH:doc*) (or (tblsearch "layer" "Contour Label") (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") '(2 . "Contour Label") '(62 . 7) '(70 . 0) ) ) ) (or *MHY:Scale* (setq *MHY:Scale* 50)) (and (progn (initget 6) (setq *MHY:Scale* (cond ((getint (strcat "\nSet Scale (50,100,200,250,500,etc) < " (itoa *MHY:Scale*) " > : " ) ) ) (*MHY:Scale*) ) ) ) (setq prc (getvar 'DIMZIN)) (setvar 'DIMZIN 0) (while (and (setq sel (entsel "\nSelect contour at point to label: ")) (setq ent (car sel) pos (cadr sel) ) (or (setq typ (wcmatch (cdr (assoc 0 (entget ent))) "AECC_CONTOUR,*POLYLINE" ) ) (alert "Invalid object!. Try again") t ) ) (and typ (setq cls (vlax-curve-getclosestpointto ent pos)) (setq ang (angle '(0. 0. 0.) (vlax-curve-getfirstderiv ent (vlax-curve-getparamatpoint ent cls) ) ) ) (setq txt (entmakex (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") (cons 10 cls) (cons 1 (rtos (last cls) 2 2)) (cons 40 (* 0.00175 *MHY:Scale*)) (cons 8 "Contour Label") '(50 . 0.0) '(71 . 5) '(72 . 5) '(73 . 1) '(210 0.0 0.0 1.0) ) ) ) (or (vlax-put (setq txt (vlax-ename->vla-object txt)) 'Backgroundfill 1 ) t ) (vlax-put txt 'Rotation (@ang ang)) ) ) ) (*error* nil) ) (vl-load-com) (defun @ang (ang) (if (<= (* 0.5 pi) ang (* 1.5 pi)) (+ ang pi) ang ) ) Quote
Tharwat Posted June 20, 2023 Posted June 20, 2023 34 minutes ago, mhy3sx said: Thank you Tharwat. You are welcome anytime. Quote
MER110624 Posted November 6 Posted November 6 This lisp almost works for us. I need to change the text style from standard to one of ours. I hope that sets the height using the style. What parameters are being used for the text style? Quote
MER110624 Posted November 6 Posted November 6 oh and How to make the label have no decimal places too. Thanks for any help. Quote
Steven P Posted November 7 Posted November 7 Using Tharwats code? Look at this section (setq txt (entmakex (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") (cons 10 cls) (cons 1 (rtos (last cls) 2 2)) (cons 40 (* 0.00175 *MHY:Scale*)) (cons 8 "Contour Label") '(50 . 0.0) '(71 . 5) '(72 . 5) '(73 . 1) '(210 0.0 0.0 1.0) ) ) ) Add '(7 . "Text_Style") where text style is your font in between '(50 . ...) and '(71 . ...). Here using Standard text style: '(50 . 0.0) '(7 . "Standard") '(71 . 5) For height modify the (cons 40 (* 0.00175 *MHY@Scale*)) if necessary. Either change the 0.00175 to a different number or replace the whole (* 0.00175 *MHY:Scale*) to a value if you want the same height all the time eg. (cons 40 2.5) 1 Quote
MER110624 Posted November 7 Posted November 7 Yes Tharwats code. Let me give those changes a whirl. Thanks!! Quote
MER110624 Posted November 7 Posted November 7 Yes those fixes worked I almost have what I want. Need to make the label have no decimal places too. Comes in like first image but need second: Quote
BIGAL Posted November 7 Posted November 7 A very simple answer is, it is your turn to do a little home work and learn at same time. Google "RTOS Autodesk" Have a look in the code you should be able to find it very quickly what to change. 1 1 Quote
MER110624 Posted November 8 Posted November 8 I am not the best at lisp routines but can edit them ok. Thanks for the lesson. I went online and found the syntax and edited it and now it is working well. (cons 1 (rtos (last cls) 2 0)) 1 Quote
Steven P Posted November 8 Posted November 8 Perfect - to be honest that is a much better answer than us just giving you the syntax! A little hint from BigAl, a bit of confidence that you can change the code and we can retire now? Quote
