sujata kashyap Posted June 15, 2023 Share Posted June 15, 2023 Hi all. I hope everybody is Good , I need some help. How do i move the text with equal spacing, The distance between the text is fix or as long as user can read it. How do i create the lines? I'm new to Autolisp, so please avoid giving example in Visual Lisp (vlx), if anyone has some lisp(.lsp) related to this kindly share. kindly find the link to resolve my problem. https://drive.google.com/drive/folders/1FZxxxzCS6Ann3cm9O2pV0dGmNdCvMey3?usp=sharing Thanks. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 15, 2023 Share Posted June 15, 2023 Overlapping text has been a problem for years, you realign them then they overlap another text that you have Un-overlapped. Any way if you take the text and say make into Mtext with color then it will be stacked automatically, this would be easiest. So confirm that is Ok. Other version would be just to stack the text based on the text height. The only problem is if the text is annotative then it may move depending on Anno scale. So choice is yours but need a sample dwg, looks like the text is in different layers so need that result order, a before and after sample. 1 Quote Link to comment Share on other sites More sharing options...
