Steven P Posted June 14, 2023 Share Posted June 14, 2023 Hello, Not sure if this is related but I had a Civil 3D update yesterday... and now double clicking on text doesn't open it for editing (M or D texts), it needs a triple click, and pickfirst of a block and then bedit, or double click it, won't open that block directly to edit - it goes to the Edit Block Definition dialog (select a block) as if the block wasn't preselected (all well and good till you have a lot of blocks in a drawing) (double click text gives me "Textedit Select an annotation object or [undo mode]", bock editor dialogue is opening so double click starts a command still but doesn't do what I think it should) So what has it changed? I've tried the usual Pickfirst, Dblclkedit, Double Click actions in the CUI look OK, and so on - no changes from me.... The usual fixes arn't working... so what have I missed or have 'they' done something? Thanks Quote Link to comment Share on other sites More sharing options...
Steven P Posted June 19, 2023 Author Share Posted June 19, 2023 For future information, QAFlags reset to 0 fixes the block editing part. Think that was part my fault cancelling a LISP part way through it running. Now for double clicking text, will keep thinking Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 19, 2023 Share Posted June 19, 2023 I had a LISP I was working on that when it errored the right-click wasn't working. A restart of AutoCAD fixed it, but then my ACADDOC resets my SysVars. Try a repair if a restart doesn't work. Did you check Autodesk Civil 3D Forum to see if it's a bug? 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted June 19, 2023 Author Share Posted June 19, 2023 I've added this to my start-up just now I'll have a look in the forum - the update was only last week so wanted to give a few days for forums to chat about it and think of a solution - I'll check later (repair after) Thanks Quote Link to comment Share on other sites More sharing options...
