diogenes666 Posted June 10, 2023 Share Posted June 10, 2023 (edited) Good morning to all. I have a big problem with the new version of Autocad 2024. I have made an application in Visuallisp that uses Ldata, Xdata dictionaries and object reactors. In previous versions of Autocad, it worked perfectly. In ACAD2024, when plotting, it becomes incredibly slow. Does anyone have any idea what has changed? If you can help me with the attached drawing, I would be very grateful. Regards PEDIDO.dwg Edited June 10, 2023 by diogenes666 Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 10, 2023 Share Posted June 10, 2023 I don't think its a lisp is slowing you down. https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/plotting-takes-a-long-time-to-complete-in-autocad.html Quote Link to comment Share on other sites More sharing options...
diogenes666 Posted June 11, 2023 Author Share Posted June 11, 2023 (edited) Thank you very much for your response. The curious thing is that once the drawing I have attached is generated, as long as I don't close it and reopen it, it plots fast. If I close and reopen, that's when it becomes very slow to print, regardless of whether I load the lisp applications or not. The link you provided, doesn't really give valid answers. I have searched several Autodesk posts and there is no credible solution. I suppose I will have to wait for the corresponding Autocad update that fixes the problem. Thank you very much for your input. Regards Edited June 11, 2023 by diogenes666 Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 11, 2023 Share Posted June 11, 2023 3 hours ago, diogenes666 said: I suppose I will have to wait for the corresponding Autocad update that fixes the problem. Good luck, last thing before switching over to BricsCAD was the wipeout was creating black areas when printing to PDF. Autocad response to me was wait til the next version comes out Should be fixed by then. If the problem doesn't affecting a lot of users they won't put much time/effort into it. one last thing I saw when searching. Quote chrapmannZD2ML 08-03-2018 08:10 AM I figured out the bottleneck. Polygon Viewports must cause the PDF viewers to view/print the files as raster images instead of vectors. Using the standard rectangular viewports have fixed the issues and brought my drawings back to printing normal and fast like previous projects. Thanks Quote Link to comment Share on other sites More sharing options...
diogenes666 Posted June 14, 2023 Author Share Posted June 14, 2023 Thank you for your feedback. In my case I don't use Vports, so it doesn't seem to be the cause of the problem either, but good to know. The Bricscad option is the one I'm evaluating, because testing, I have no problems when printing. Regards Quote Link to comment Share on other sites More sharing options...
diogenes666 Posted June 19, 2023 Author Share Posted June 19, 2023 Hello everybody. I have finally deduced where the problem comes from. I have opened the same drawing from the local hard drive and from a network location. In the first case, it works as usual. In the second case is when autocad becomes very slow, even when I use the options command. According to some answers in Autodesk forum, one way to solve it, is to copy the network file in the local hard disk, and when you finish modifying the drawing, copy it back to the network. Whatever they call fixing a problem. Regards Quote Link to comment Share on other sites More sharing options...
Steven P Posted June 19, 2023 Share Posted June 19, 2023 Maybe I'm dinosaur age but years before we had online, or virtual drives, the were all on a local disk in the office (backed up to somewhere in the company somewhere else), worked well. Then they decided we wanted to work on virtual drives.. and added problems. Mind there was also the beauty of a Citrix connection over a dialup modem in the site cabins then too, "Why are you looking out the window again" "Opening a file.. I'll come back to reality in 15 minutes" Quote Link to comment Share on other sites More sharing options...
mhupp Posted June 19, 2023 Share Posted June 19, 2023 See if adding the network location to trusted folder location would fix that. its 2023 working off network drives isn't something new. and your network should be at least a gigbit speed. other factors could slow network speeds down. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 20, 2023 Share Posted June 20, 2023 (edited) Were I worked 1000 pc's etc and everything was done on a network no speed problems but we did have a Optic fibre backbone. It connected all offices including some 25km away. With work at home now there was still a good download speed so like others may be a network problem. Edited June 20, 2023 by BIGAL Quote Link to comment Share on other sites More sharing options...
diogenes666 Posted June 26, 2023 Author Share Posted June 26, 2023 Thank you for your comments. I will do the tests to see if it will work out. In previous versions of Autocad and with the same network infrastructure, it worked without problems. I will also try adding the network drive to the list of trusted folders. Thanks and best regards Quote Link to comment Share on other sites More sharing options...
awesomepasta Posted October 4, 2023 Share Posted October 4, 2023 I also have the same problem. Whenever I choose a function, it takes about a minute of two until it works on CAD. It's getting irritating and I regret downloading this version! Quote Link to comment Share on other sites More sharing options...
