Get coordinates of 3rd point based on known distance between it and 1st and 2nd point?
Try this:
(defun c:pp(/); l1 l2 l3 p1 p2 p3 p4 p area h h1 ang)
  (setq l1 3.0 l2 2.0 l3 4)
  (setq p1 (list 0 0) p2 (list 0 l1))
  (setq p (* (+ l1 l2 l3) 0.5))
  (setq area (sqrt (* p (- p l1) (- p l2) (- p l3))))
  (setq h (/ area l1 0.5))
  (setq h1 (sqrt (- (* l2 l2) (* h h))))
  (setq ang (atan h h1))
  (setq ang (if (> (* l3 l3) (+ (* l1 l1) (* h h))) (- PI ang) ang))
  (setq p3 (polar p1 (+ ang (angle p1 p2)) l2))
  (setq p4 (polar p1 (- (angle p1 p2) ang) l2))
  (command "line" p1 p2 p3 p1 p4 p2 "")
  • Thanks 1
@fuccaro
Thank you very much it's working perfectly now.
My old code would process 2000 triangles and draw outline in 35 seconds in wireframe view and 1m10s in shaded, with this algorithm it takes 3 seconds regardless of the view type. Huge improvement!
Edited by vanowm
Wow! that's more than 10 times faster!
Even if I wrote that Lisp in a rush, I felt good lisping. Enjoy!
  • 4 weeks later...
After reading again the program, I can see that it can be improved for speed. Not big deal, but the variable “h” is raised at square twice, in two different program lines. You could place the result of (* h h) in a variable when it first occurs, and use that value instead of calculating it again.
With this change it will process those 2000 triangles in 2.99999999 secs instead of 3! 😊
Expand
Just need to do that 4,000,000 times in a day and that's me gaining enough time for a nice cup  of tea!! (however also to make future updates easier I find doing a calculation once, as a variable, means I only have to update it once)
Here's another possible method -
(defun tri-ppll ( p1 p2 l1 l2 / a b p x )
    (if (< 0 (setq a (distance p1 p2)))
        (setq b (* l1 l1)
              x (/ (+ (- (* a a) (* l2 l2)) b) (+ a a))
              p (mapcar '+ p1 (trans (list (sqrt (- b (* x x))) 0.0 x) (mapcar '- p2 p1) 0))
To test:
(defun c:test ( / a b p q x )
    (if (and (setq p (getpoint "\nSpecify 1st point: "))
             (setq q (getpoint "\nSpecify 2nd point: "))
             (setq a (getdist p "\nSpecify 1st side length: "))
             (setq b (getdist q "\nSpecify 2nd side length: "))
        (if (setq x (tri-ppll p q a b))
            (mapcar 'l (list p q x) (list q x p))
            (princ "\nThe two points must be distinct!")
(defun l ( a b ) (entmake (list '(0 . "LINE") (cons 10 a) (cons 11 b))))
Edited by Lee Mac
Would a defun for entmake pline '(p1 p2 p3 p1 p4 p2) then explode maybe take 2.9 seconds ? 😃
Edited by BIGAL
Expand
I don't understand your point? The purpose of the function is to calculate the points...
Expand
Think he was refereing to Fuccaros comment on saving 0.00001 by a second with a slight change in the code - rather than the code itself
I was just having a laugh shaving micro seconds may be all you gain some times for an hours work.
Yes have code huge task took 45  minutes 1st go using command, 3rd version is now 2 minutes. Using entmakes and VL. Versus manual edit was around 4 hours so client is very happy.
Edited by BIGAL
You could charge your client by hour 😈
