LISP for Selection of alternate lines from the selection set of lines like 1st, 3rd, 5th, .....etc lines in autocad.
Hello guys,
I am new to this forum.
I need LISP for Selection of alternate lines from the selection set of lines like 1st, 3rd, 5th, .....etc lines in Autocad.
I am attaching the file with my requirement.
Alternate Selection of lines.dwgFetching info...
Please help me out with an possible lisp solution.
Also,
Is there a Autocad Plugin to do this?
If so Please share the link
Thanks in advance,
Pranesh Rathinam
(defun c:t1 ( / ss l mid-pt ss->el)
  (defun mid-pt (e / x)
    (setq x (entget e))(mapcar '* (mapcar '+ (cdr (assoc 10 x)) (cdr (assoc 11 x))) '(0.5 0.5 0.5)))
  (defun ss->el (ss / i l)
    (setq i 0)(repeat (sslength ss)(setq l (cons (ssname ss i) l) i (1+ i))) l)
  (if (setq ss (ssget (list (cons 0 "Line"))))
    (setq l (vl-sort (ss->el ss) '(lambda (a b) (< (cadr (mid-pt a)) (cadr (mid-pt b)))))))
  (setq ss (ssadd) i -2)
  (while (setq e (nth (setq i (+ i 2)) l))(ssadd e ss))
  (command "chprop" ss "" "color" "red" "")
load code , start with t1 or (c:t1) , select the lines with window or crossing (no problem selecting the leaders also because they are filtered out anyway so don't worry , be happy) et voila...
Edited by rlx
add comments on how to use
  • Like 3
If lines all have same Y midpoint, vertical lines then the sort may not get correct order maybe a sort X&Y car & cadr.
	 '(lambda (a b)
	    (cond
	      ((< (car (mid-pt a)) (car (mid-pt b))))
	      ((= (car (mid-pt a)) (car (mid-pt b))) (< (cadr (mid-pt a)) (cadr (mid-pt b))))
Thank you rlx & BIGAL for your valuable replies.
Now it is possible to select alternate line using quick select after the coloring happens to red with the help of the above lisp.
I have achieved my need thank you so much
Also Please do help me with gaining a small clarity about the same LISP,
  1. Is this LISP can be made/modified to select lines at the end of the LISP execution(As the result out of 150 lines 75 lines alternatively at the end of the LISP execution without changing the color)?
  2. Is there any option to control which alternate lines to get selected (I mean 1st, 2nd, 3rd,...... or 2nd,4th,6th,.....) can an option can be set for this in above same LISP?
Ok good time to start to learn lisp and the way some things work.
This sets 2 variables (setq ss (ssadd) i -2) so the ss is a blank selection and i is set to -2
(nth (setq i (+ i 2)) l)) this gets a item from the sorted points l, to get the 1st item in a list of points it is referenced as starting at zero 0, so if i =-2 then (setq i (+ i 2)) = 0 next will be items (nth 2 4 6 etc so if want even lines (setq ss (ssadd) i -1) this will result in (nth 1 3 5 7 etc
Keep a selection of lines is done already its ss.
You need to look into using IF's so you can ask a question like change color, even or odd.
(setq ans (getstring "\nChange color Y or N "))
(if (or (= ans "Y")(= ans "y"))
