MUTHUKUMAR1983 Posted May 16, 2023 Posted May 16, 2023 (DEFUN C:FLR() (COMMAND "PDMODE" 3)(COMMAND "-LAYER" "S" "Field-Line" "") (SETQ P1(GETPOINT "\n PICK FIELD LINE START POINT :") P2(GETPOINT P1 "\n PICK FIELD LINE END POINT :") P3(GETPOINT P1 "\n PICK RIGHT SIDE :") AN1(ANGLE P1 P2) ) (COMMAND "UCS" "3" P1 P2 P3 "") (REPEAT 100 (vl-vbaload "E:/FMB Cadd/Field Line.dvb") (VL-VBARUN "FL") (SETQ GS(GETSTRING "\n FIELD LINE NUMBER :") YV(GETREAL "\n ENTER LINE LENGTH VALUE:") XV(GETREAL "\n ENTER OFFSET VALUE:") th(atof(getvar "users1")) ) ; (COMMAND "DELAY" 60) ;(COMMAND "POINT" (LIST XV YV) ) (COMMAND "CIRCLE" (LIST XV YV)(+ TH 0.2) ) ;(COMMAND "DELAY" 60) (ENTMAKE (LIST (CONS 0 "TEXT") (CONS 100 "AcDbEntity") (CONS 100 "AcDbText") (CONS 10 (trans (LIST XV YV) 1 0)) ; POINT (CONS 40 th) (CONS 7 (GETVAR 'textstyle)) (CONS 8 (getvar "CLAYER")) (CONS 62 1) (CONS 1 GS) ;VALUE (CONS 50 0 ) (CONS 72 1) (CONS 11 (LIST XV YV)) (CONS 73 2) )) ) (vl-vbaload "E:/FMB Cadd/Field Line.dvb");testdial (VL-VBARUN "FL") ) Quote
Isaac26a Posted May 16, 2023 Posted May 16, 2023 (edited) Use this ;;; just72 (left->0, center->1, right->2,aligned (if vertical alignment=0)->3) ;;; just73 (baseline->0, bottom->1, middle->2,top->3) (cons 72 just72) ;;; Horizontal Alignment (cons 73 just73) ;;; Vertical Alignment ;; or if you are using "just" numbers '(72 . 1) '(73 . 2) And the insertion point should be 11 instead of 10 Edited May 16, 2023 by Isaac26a 2 Quote
Steven P Posted May 16, 2023 Posted May 16, 2023 These have always worked for me if you don't want to entmod the text. (defun c:jul() (jut "l")) ;;ju: Justify + l: Left (defun c:juc() (jut "c")) ;; c: centre (defun c:jur() (jut "r")) ;; r: right (defun c:jutl() (jut "tl"));; t: top (defun c:jutc() (jut "tc")) (defun c:jutr() (jut "tr")) (defun c:juml() (jut "ml"));; m: middle (defun c:jumc() (jut "mc")) (defun c:jumr() (jut "mr")) (defun c:jubl() (jut "bl"));; b: Bottom (defun c:jubc() (jut "bc")) (defun c:jubr() (jut "br")) (defun jut (just / var ent) (setq var (getvar "CMDECHO")) (setvar "CMDECHO" 0) ;;https://www.cadtutor.net/forum/topic/35569-text-justification-lisp/ (princ (strcat "\nSelect Text")) (if (setq ss (ssget "_:L" '((0 . "ATTDEF,MTEXT,TEXT")))) (command "_.justifytext" ss "" just) ) (setvar "CMDECHO" var) (princ) ) 1 Quote
