help ...with routine select by viewport
leonucadomi
hello:
a while ago they gave me a code which is used to copy model space objects
selecting a viewport , instead of selecting a viewport  I would like to modify it to make a selection in the window
from paperspace and select the objects inside that area to be able to copy them.
any help is welcome thanks
(vl-load-com)
(defun l-coor2l-pt (lst flag / )
    (if lst
        (cons (list (car lst) (cadr lst) (if flag (caddr lst) 0.0))
            (l-coor2l-pt (if flag (cdddr lst) (cddr lst)) flag)
(defun c:sv ( / AcDoc Space js pt_v id_vp l h lst_pt js_obj UCS save_ucs WSC nw_pl ob_lst_pt vps inv-vps)
  (setvar "CMDECHO" 0)
    (setq
    AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
    Space (vla-get-PaperSpace AcDoc)
  (vla-StartUndoMark AcDoc)
  (if (eq (getvar "CTAB") "Model") (setvar "TILEMODE" 0))
  (command "_.PSPACE")
  (princ "\nSelect a viewport: ")
  (while
    (null
      (setq js
        (ssget "_+.:E:S:L"
          (list
            '(0 . "VIEWPORT")
            '(67 . 1)
            (cons 410 (getvar "CTAB"))
            '(-4 . "!=")
            '(69 . 1)
  (setq
    pt_v (cdr (assoc 10 (setq dxf_ent (entget (setq ent (ssname js 0))))))
    id_vp (cdr (assoc 69 dxf_ent))
    l (cdr (assoc 40 dxf_ent))
    h (cdr (assoc 41 dxf_ent))
    lst_pt
    (list
      (list (- (car pt_v) (* 0.5 l)) (- (cadr pt_v) (* 0.5 h)) 0.0)
      (list (+ (car pt_v) (* 0.5 l)) (- (cadr pt_v) (* 0.5 h)) 0.0)
      (list (+ (car pt_v) (* 0.5 l)) (+ (cadr pt_v) (* 0.5 h)) 0.0)
      (list (- (car pt_v) (* 0.5 l)) (+ (cadr pt_v) (* 0.5 h)) 0.0)
    js_obj (ssadd)
  (entmakex
    (vl-list*
      (cons 0 "LWPOLYLINE")
      (cons 100 "AcDbEntity")
      (cons 67 1)
      (cons 100 "AcDbPolyline")
      (cons 90 (length lst_pt))
      (cons 70 1)
      (mapcar '(lambda (p) (cons 10 p)) lst_pt)
  (ssadd (setq nw_pl (entlast)) js_obj)
(setq vps (vla-get-CustomScale (vlax-ename->vla-object (ssname js 0))))
(setq inv-vps (/ 1 vps))
  (command "_.MSPACE")
  (setvar "CVPORT" id_vp)
  (command "_.CHSPACE" js_obj "" (if (> id_vp 2) ""))
  (setq
    Space
    (if (eq (getvar "CVPORT") 1)
      (vla-get-ModelSpace AcDoc)
    UCS (vla-get-UserCoordinateSystems AcDoc)
    save_ucs
    (vla-add UCS
      (vlax-3d-point '(0.0 0.0 0.0))
      (vlax-3d-point (getvar "UCSXDIR"))
      (vlax-3d-point (getvar "UCSYDIR"))
      "CURRENT_UCS"
  (vla-put-Origin save_ucs (vlax-3d-point (getvar "UCSORG")))
  (setq WCS (vla-add UCS (vlax-3d-Point '(0.0 0.0 0.0)) (vlax-3d-Point '(1.0 0.0 0.0)) (vlax-3d-Point '(0.0 1.0 0.0)) "TEMP_WCS"))
  (vla-put-activeUCS AcDoc WCS)
  (setq
    nw_pl (vlax-ename->vla-object nw_pl)
    ob_lst_pt (l-coor2l-pt (vlax-get nw_pl 'coordinates) nil)
  (vla-put-layer nw_pl "0")
  (vla-delete nw_pl)
  ;(sssetfirst nil (ssget "_WP" ob_lst_pt ))
  (setq objetos (ssget "_WP" ob_lst_pt ))
  (command "_copyclip" objetos "")
  (and save_ucs (vla-put-activeUCS AcDoc save_ucs))
  (and WCS (vla-delete WCS) (setq WCS nil))
  (vla-EndUndoMark AcDoc)
  (setvar "CMDECHO" 1)
  (prin1)
