Hi everyone,
I am trying to make a block with a rotation parameter. Two lines connected with a rounded corner. One line you can rotate. The arc follows the rotation but should adjust accordingly to the angle between the lines, the radius stays constant.
Can someone give me a kickstart to solve this??
RotationBlock_withFillet.dwgUnavailable
  • 2 weeks later...
Something like this? I used the center of the arc as the rotation point which only works on the vertical. I added a horizontal constraint to the horizontal line. I the used a coincident and tangent constraint where both line and the arc meet.
test block.dwgFetching info...
