adylon Posted May 4, 2023 Posted May 4, 2023 Hi everyone, I am trying to make a block with a rotation parameter. Two lines connected with a rounded corner. One line you can rotate. The arc follows the rotation but should adjust accordingly to the angle between the lines, the radius stays constant. Can someone give me a kickstart to solve this?? RotationBlock_withFillet.dwgFetching info... Quote
Bob658 Posted May 18, 2023 Posted May 18, 2023 Something like this? I used the center of the arc as the rotation point which only works on the vertical. I added a horizontal constraint to the horizontal line. I the used a coincident and tangent constraint where both line and the arc meet. test block.dwgFetching info... Quote
