Two Lee Mac reactors with automatic start-up
Nikon
Good day everyone! The two Lee Mac Layer Director V1-9.lsp and Mteditreactor V1-1.lsp reactors,
which should be turned on automatically at boot, are turned on only one at a time. That is, the second reactor must be turned on forcibly if
the first one is active. Is it possible to automatically turn on two reactors at the same time ? I really hope for the help of the author Lee Mak, thank you.
MTEditReactorV1-1.lsp LayerDirectorV1-9.lsp
Edited by Nikon
Didn''t you ask the same here:
Not sure of an answer but if you make up a little LISP, remove these from starting automatically, and add this one to run when the drawing opens
(defun reactors ( / )
  (load "--FILE PATH OF REACTOR FILE-- \\LayerDirector V1-9.lsp" "Reactor 1 Failed to Load")
  (load "--FILE PATH OF REACTOR FILE-- \\Mteditreactor V1-1.lsp" "Reactor 2 Failed to Load")
