Reaper_of_Lykos Posted May 2, 2023 Share Posted May 2, 2023 Hello, I have a simple drawing with a few enclosed polylines. I am trying to use the area function to compute their areas. My code looks like this: ;prompt user to select all polylines to compute area in one go. (setq ss (ssget)) (setq tot (sslength ss)) ;get total area of all spaces (setq areaTot 0) (setq iter 0) (while (< iter tot) (setq space (entget (ssname ss iter))) (command "area" "o" space) <<------This line is obviously the problem (setq areaTot (+ areaTot (getvar "area"))) (setq iter (+ iter 1)) ) (print areaTot) But clearly this doesn't work, as area function is expecting an "object" input while I'm giving it an entity. But what data format is it looking for exactly? How to make entity an object? Thank you. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted May 3, 2023 Share Posted May 3, 2023 Weclome to CADTutor ;; Change this (setq space (entget (ssname ss iter))) (command "area" "o" space) (setq areatot (+ areatot (getvar "area"))) ;; To this (setq space (ssname ss iter)) (setq areatot (+ areatot (vlax-curve-getarea space))) 1 Quote Link to comment Share on other sites More sharing options...
Reaper_of_Lykos Posted May 3, 2023 Author Share Posted May 3, 2023 3 hours ago, ronjonp said: Weclome to CADTutor ;; Change this (setq space (entget (ssname ss iter))) (command "area" "o" space) (setq areatot (+ areatot (getvar "area"))) ;; To this (setq space (ssname ss iter)) (setq areatot (+ areatot (vlax-curve-getarea space))) Thank you ronjonp, that works great. I am looking into vlax now because of your answer and that seems to unlock a whole new world of functionalities! Quote Link to comment Share on other sites More sharing options...
ronjonp Posted May 3, 2023 Share Posted May 3, 2023 (edited) You should also put in a filter for the objects selected. If you select a block the code will fail on vlax-curve-getarea. Something like this: (setq ss (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*POLYLINE,REGION,SPLINE")))) Edited May 3, 2023 by ronjonp Quote Link to comment Share on other sites More sharing options...
Reaper_of_Lykos Posted May 3, 2023 Author Share Posted May 3, 2023 2 hours ago, ronjonp said: You should also put in a filter for the objects selected. If you select a block the code will fail on vlax-curve-getarea. Something like this: (setq ss (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*POLYLINE,REGION,SPLINE")))) Thank you for that! Quote Link to comment Share on other sites More sharing options...
ronjonp Posted May 3, 2023 Share Posted May 3, 2023 4 minutes ago, Reaper_of_Lykos said: Thank you for that! Not a problem! Quote Link to comment Share on other sites More sharing options...
Reaper_of_Lykos Posted May 4, 2023 Author Share Posted May 4, 2023 (edited) Quote (setq ss (ssget '((0 . "ARC,CIRCLE,ELLIPSE,*POLYLINE,REGION,SPLINE")))) Hi ronjonp, one follow up question I hope to ask is, what does the * before POLYLINE do? Thank you! Edited May 4, 2023 by Reaper_of_Lykos Quote Link to comment Share on other sites More sharing options...
ronjonp Posted May 4, 2023 Share Posted May 4, 2023 3 minutes ago, Reaper_of_Lykos said: Hi ronjonp, one follow up question I hope to ask is, what does the * before POLYLINE do? Thank you! It grabs lightweight polylines( LWPOLYLINE ) and 'heavy' 2D polylines ( POLYLINE ). Look at the objects listed in light blue HERE. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 5, 2023 Share Posted May 5, 2023 Use dumpit to see VL properties one of those must have programs. ;;;===================================================================; ;;; DumpIt ; ;;;-------------------------------------------------------------------; ;;; Dump all methods and properties for selected objects ; ;;;===================================================================; (defun C:Dumpit ( / ent) (while (setq ent (entsel)) (vlax-Dump-Object (vlax-Ename->Vla-Object (car ent)) ) ) (princ) ) also (defun c:entdump () (entget (car (entsel "\Pick object "))) ) Quote Link to comment Share on other sites More sharing options...
