Hello every one, i need a lisp for draw alighment with offset with curve
Explain more, why not just use offset and make new alignments, thats the way we did it multiple  road jobs a year.
can you  attach an example drawing
what i want is alighiment with offset in civil 3d and multiline in autocad but with curve
simply i want to draw polyline with curve
Expand
Maybe
Can you use get polyline from alignment  method
Edited by hosneyalaa
Yeah Civ3d has a little nasty make an alignment from a pline and forget don't erase so original pline is gone. Just remember to freeze the layer with all the alignment plines on it.
"Civil Site Design" does all the cleaning up for you reads the road template and when add kerb returns joins the correct strings as it draws the radius or another alignment linking 2 roads.
Edited by BIGAL
