Hi Guys
The handy useful lisp  TCountV1-1.lsp by Mr LEE MAC in the following address exists
;;--------------------=={ Text Count }==----------------------;;
;;  Counts the number of occurrences of each string in a      ;;
;;  selection and produces a report in an ACAD Table object   ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Version 1.0  -  07.11.2010                                ;;
;;  First Release.                                            ;;
;;  Version 1.1  -  05.08.2011                                ;;
;;  Added Dimensions Override Text & MLeaders                 ;;
;;  Updated 'AddTable' to account for Annotative Text Styles. ;;
(defun c:tCount
    *error*
    _StartUndo
    _Assoc++
    _SumAttributes
    _GetTextString
    _ApplyFooToSelSet
    acdoc
    acspc
    data
    pt
  (defun *error* ( msg )
    (if acdoc (_EndUndo acdoc))
    (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
      (princ (strcat "\n** Error: " msg " **"))
    (vla-StartUndoMark doc)
    (if (= 8 (logand 8 (getvar 'UNDOCTL)))
      (vla-EndUndoMark doc)
  (defun _Assoc++ ( key alist )
      (lambda ( pair )
        (if pair
          (subst (list key (1+ (cadr pair))) pair alist)
          (cons  (list key 1) alist)
      (assoc key alist)
  (defun _SumAttributes ( entity alist )
    (while
      (not
        (eq "SEQEND"
          (cdr
            (assoc 0
              (entget
                (setq entity (entnext entity))
      (setq alist (_Assoc++ (_GetTextString entity) alist))
  (defun _GetTextString ( entity )
      (lambda ( string )
        (mapcar
          (function
            (lambda ( pair )
              (if (member (car pair) '(1 3))
                (setq string (strcat string (cdr pair)))
          (entget entity)
        string
  (defun _ApplyFooToSelSet ( foo ss / i )
    (if ss (repeat (setq i (sslength ss)) (foo (ssname ss (setq i (1- i))))))
  (setq acdoc (vla-get-activedocument (vlax-get-acad-object))
        acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))
  (cond
    ( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'CLAYER))))))
      (princ "\nCurrent Layer Locked.")
    ( (not (vlax-method-applicable-p acspc 'AddTable))
      (princ "\nTable Object not Available in this version.")
    ( (and
          (_ApplyFooToSelSet
            (lambda ( entity / typ )
                (cond
                  ( (eq "INSERT" (setq typ (cdr (assoc 0 (entget entity)))))
                    (_SumAttributes entity alist)
                  ( (eq "MULTILEADER" typ)
                    (_Assoc++ (cdr (assoc 304 (entget entity))) alist)
                  ( (wcmatch typ "*DIMENSION")
                    (_Assoc++ (cdr (assoc 1 (entget entity))) alist)
                  ( (_Assoc++ (_GetTextString entity) alist) )
            (ssget
                (-4 . "<OR")
                  (0 . "TEXT,MTEXT,MULTILEADER")
                  (-4 . "<AND")
                    (0 . "INSERT")
                    (66 . 1)
                  (-4 . "AND>")
                    (0 . "*DIMENSION")
                    (1 . "*?*")
                (-4 . "OR>")
        (setq pt (getpoint "\nSpecify Point for Table: "))
      (_StartUndo acdoc)
      (LM:AddTable acspc (trans pt 1 0) "String Count"
        (cons (list "String" "Instances")
          (vl-sort
            (mapcar
              (function
                (lambda ( x ) (list (car x) (itoa (cadr x))))
              data
            (function (lambda ( a b ) (< (car a) (car b))))
      (_EndUndo acdoc)
;;---------------------=={ Add Table }==----------------------;;
;;  Creates a VLA Table Object at the specified point,        ;;
;;  populated with title and data                             ;;
;;  Arguments:                                                ;;
;;  space - VLA Block Object                                  ;;
;;  pt    - Insertion Point for Table                         ;;
;;  title - Table title                                       ;;
;;  data  - List of data to populate the table                ;;
;;  Returns:  VLA Table Object                                ;;
(defun LM:AddTable ( space pt title data / _isAnnotative textheight style )
  (defun _isAnnotative ( style / object annotx )
    (and
      (setq object (tblobjname "STYLE" style))
      (setq annotx (cadr (assoc -3 (entget object '("AcadAnnotative")))))
      (= 1 (cdr (assoc 1070 (reverse annotx))))
    (lambda ( table ) (vla-put-StyleName table (getvar 'CTABLESTYLE)) (vla-SetText table 0 0 title)
        (lambda ( row )
          (mapcar
            (function
              (lambda ( rowitem ) (setq row (1+ row))
                  (lambda ( column )
                    (mapcar
                      (function
                        (lambda ( item )
                          (vla-SetText table row (setq column (1+ column)) item)
                      rowitem
                  -1
            data
        0
      table
      (lambda ( textheight )
        (vla-AddTable space (vlax-3D-point pt) (1+ (length data)) (length (car data)) textheight
          (* 0.8 textheight
            (apply 'max
              (cons (/ (strlen title) (length (car data)))
                (mapcar 'strlen (apply 'append data))
      (* 2.
          (setq textheight
            (vla-gettextheight
              (setq style
                (vla-item
                  (vla-item
                    (vla-get-dictionaries (vla-get-document space)) "ACAD_TABLESTYLE"
              acdatarow
          (if (_isAnnotative (vla-gettextstyle style acdatarow))
            (cond ( (getvar 'CANNOSCALEVALUE) ) ( 1.0 ))
            1.0
;;                         End of File                        ;;
After running it everything went pretty well, but the drawn table in the result was really big and needed to be smaller in convenience.
I tried to find a way for giving the result by 0.1 scale. unluckily I couldn't do that.
How we can do that ??
Edited by hosyn
Why can't you scale it :
          (vl-sort
            (mapcar
              (function
              data
      (vl-cmdf "_.SCALE" (entlast) "" "_non" (trans pt 1 0) 0.1 "") ;;; scale factor = 0.1
Thank you Marko for soonly helping, I added
as you mentioned at the bottom, the result scaling was excellent but I had this error message in the command prompt:
Command: TCOUNT
Select objects: Specify opposite corner: 12 found
Select objects:
Specify Point for Table: Unknown command "TCOUNT".  Press F1 for help.
How can deal with this massage and heal it
REALY APPRECIATE MATE
Instead of this :
try it with this :
(vl-cmdf "_.SCALE" (entlast) "" "_non" (trans pt 1 0) 0.1)
The size of the table is dependent upon the text height configured for a data row in your current Table Style; as such, if you were to configure your Table Style accordingly, you can avoid the additional scaling step.
10 hours ago, marko_ribar said:
Instead of this :
try it with this :
Excellent.,Marko,
just that for a second desire,
2------ If we want just count for contents including a particular string, the first ask user for the desired string and then list them in that table, what can we do????     example:
(setq txt (getstring T " Type desired text included :" ))   ;;;  here we type example :plo
all text and mtext in the selection area that includes just "*LPO*"
Edited by hosyn
Maybe change (ssget) filter :
(ssget '( (-4 . "<OR") (0 . "TEXT,MTEXT,MULTILEADER") (-4 . "<AND") (0 . "INSERT") (66 . 1) (-4 . "AND>") (0 . "*DIMENSION") (1 . "*?*") (-4 . "OR>") ) )
To :
(ssget '( (-4 . "<OR") (-4. "<AND") (0 . "TEXT,MTEXT,MULTILEADER") (1. "*LPO*") (-4 . "AND>") (-4 . "<AND") (0 . "INSERT") (66 . 1) (-4 . "AND>") (0 . "*DIMENSION") (1 . "*?*") (-4 . "OR>") ) )
Of course if you plan to acquire that "*LPO*" string, complete (ssget) must have different construction - I'll imagine that "*LPO*" is STR variable...
(ssget (list (cons -4 "<OR") (cons -4 "<AND") (cons 0 "TEXT,MTEXT,MULTILEADER") (cons 1 STR) (cons -4 "AND>") (cons -4 "<AND") (cons 0 "INSERT") (cons 66 1) (cons -4 "AND>") (cons 0 "*DIMENSION") (cons 1 "*?*") (cons -4 "OR>") ) )
Edited by marko_ribar
Thanks again Marko
I checked the recent code and unluckily not well
For clarification ssget ask us desired value for searching TEXT AND MTEXT IN SELECTION SET, here it was LPO and the result is in the following picture
Edited by hosyn
Thank you, man, good point on your codes and you're really awesome,👏
Create your own Table style and make it currant.
