Hello, Can someone help me with an AutoLisp to highlight all the dimensions in a drawing which are less than 5 Feet with a circle around it?
I am looking for an auto lisp that would help me qc my drawing by highlighting all the dimensions in the drawing that are
1. less that 5 feet
2. are unsnapped
Please and Thank you!
Dimensions, I assume you mean a dimension that you might draw using the Dimension command rather than, say a line that is less than 5' but without a dimension marker next to it?
How good are your LISP: abilities? If I give you some clues will that be enough or do you want more details?
So for part 1, dimensions less than 5 feet:
Refer to Lee Macs website: http://lee-mac.com/ssget.html and good tutorial to create a selection set, say ss, using X to select everything and with a filter (0 . "DIMENSION")
Make a while loop for the length of the selection set (sslength), and get the entity name of each as you loop (ssname ss counter), then 'entget' that and use 'assoc' looking for the list labelled 42, which is the actual measured dimension
If this is less than your distance, draw a circle
Not sure if that gives you a starter, but if not it will remind me what to do another evening
1. less that 5 feet
2. are unsnapped
Isn't this already solved HERE ?
  • Like 2
