I'm looking to create a script which will change the pagesetup of my layouts in a file. some of my old templates/ file use dont all have the same pagesetup and can be quite lengthy to change them all manually
is there a easier way to go through all tabs/ layouts in a file and change them all to (portrait & landscape will vary but should already be set ) im strugglign to find any thing which i can use as a reference to change them in a script
My way around it was ignore pagesetup and use a lisp to plot, from a menu pick output device and it all just happens. The latest version checks title blocks so can have a mix of Landscape or portrait and sheet size. It does though require company std title blocks not random plotting.
One version pick say plot A3 would send to printer on correct floor of multistorey building, that was based on user name known location, so they did not select a printer, our company 1000 pc's.
Without the use of Lisp, you can set the Pagesetup for multiple files using DWG Convert.
Someone here wrote this for me some time ago...
It takes the current page setup and copies it to all layouts.
I usually setup my first layout the way I want, give it a name then run the routine...
;; Copy current layout page setup to all layout tabs
(vl-load-com)
(defun c:test (/ Adoc Layts clyt)
(prompt "\nCopy current layout page setup to all layout tabs.")
  (setq	aDoc  (vla-get-activedocument (vlax-get-acad-object))
	Layts (vla-get-layouts aDoc)
	clyt  (vla-get-activelayout aDoc)
  (foreach
	    itm
	       (vl-remove (vla-get-name clyt) (layoutlist))
    (vla-copyfrom (vla-item Layts itm) clyt)
