lemanhhung0302 Posted April 22, 2023 Share Posted April 22, 2023 Quickly exports a table of Lines and Texts or Attribute blocks to a Table For the table of unknown attribute blocks, please use BURST command to burst all blocks first. General Usage Instructions BlockToExcel - Export table of attribute block or Lines and Texts to excel You can download the supported table styles from here https://www.mediafire.com/file/4u2zun3l12smtjc/Table_English.dwg/file If your table includes Lines and Texts or Unknown attribute blocks: 1. Run the BURST command to explode all attribute blocks 2. Run the B2E command. - Select all exploded objects. - Specify steel layer (if any). - Enter to finish command. Download: https://apps.autodesk.com/ACAD_E/en/Detail/HelpDoc?appId=4761456461459704560&appLang=en&os=Win32_64 Source: www.lisp.vn Quote Link to comment Share on other sites More sharing options...
Electronico Posted December 30, 2023 Share Posted December 30, 2023 Similar in function routine can also be found here https://cadtips.cadalyst.com/tables/export-table-lines-and-text-excel Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 30, 2023 Share Posted December 30, 2023 Also this table to excel.lsp Quote Link to comment Share on other sites More sharing options...
Danielm103 Posted May 31 Share Posted May 31 spam? you can use Python and BeautifulSoup import traceback from pyrx_imp import Rx, Ge, Gs, Db, Ap, Ed import wx import requests from bs4 import BeautifulSoup as bs import pandas as pd # sample source https://www.scraperapi.com/blog/python-loop-through-html-table/ def scraper9000(): url = "https://datatables.net/examples/styling/stripe.html" response = requests.get(url) soup = bs(response.text, "html.parser") table = soup.find("table", class_="stripe") data = { 'Name': [], 'Position': [], 'Office': [], 'age': [], 'Start date': [], 'salary': [], } for employee_data in table.find_all("tbody"): for row in employee_data.find_all("tr"): data['Name'].append(row.find_all("td")[0].text) data['Position'].append(row.find_all("td")[1].text) data['Office'].append(row.find_all("td")[2].text) data['age'].append(row.find_all("td")[3].text) data['Start date'].append(row.find_all("td")[4].text) data['salary'].append(row.find_all("td")[5].text) return data def PyRxCmd_doit(): try: db = Db.curDb() df = pd.DataFrame(scraper9000()) table = Db.Table() table.setDatabaseDefaults(db) table.setSize(df.shape[0]+2, df.shape[1]) table.setTextString(0, 0, "Scrape Master 9000") headers = df.columns.values.tolist() datas = df.values.tolist() for col, value in enumerate(headers): table.setTextString(1, col, "{}".format(value)) for row, data in enumerate(datas): for col, value in enumerate(data): table.setTextString(row+2, col, "{}".format(value)) model = Db.BlockTableRecord(db.modelSpaceId(), Db.OpenMode.kForWrite) model.appendAcDbEntity(table) except Exception as err: traceback.print_exception(err) 1 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 31 Share Posted May 31 Spammer removed. I was already suspicious of them. 1 Quote Link to comment Share on other sites More sharing options...
