lemanhhung0302 Posted April 22, 2023 Posted April 22, 2023 Quickly exports a table of Lines and Texts or Attribute blocks to a Table For the table of unknown attribute blocks, please use BURST command to burst all blocks first. General Usage Instructions BlockToExcel - Export table of attribute block or Lines and Texts to excel You can download the supported table styles from here https://www.mediafire.com/file/4u2zun3l12smtjc/Table_English.dwg/file If your table includes Lines and Texts or Unknown attribute blocks: 1. Run the BURST command to explode all attribute blocks 2. Run the B2E command. - Select all exploded objects. - Specify steel layer (if any). - Enter to finish command. Download: https://apps.autodesk.com/ACAD_E/en/Detail/HelpDoc?appId=4761456461459704560&appLang=en&os=Win32_64 Source: www.lisp.vn Quote
Electronico Posted December 30, 2023 Posted December 30, 2023 Similar in function routine can also be found here https://cadtips.cadalyst.com/tables/export-table-lines-and-text-excel Quote
Danielm103 Posted May 31, 2024 Posted May 31, 2024 spam? you can use Python and BeautifulSoup import traceback from pyrx_imp import Rx, Ge, Gs, Db, Ap, Ed import wx import requests from bs4 import BeautifulSoup as bs import pandas as pd # sample source https://www.scraperapi.com/blog/python-loop-through-html-table/ def scraper9000(): url = "https://datatables.net/examples/styling/stripe.html" response = requests.get(url) soup = bs(response.text, "html.parser") table = soup.find("table", class_="stripe") data = { 'Name': [], 'Position': [], 'Office': [], 'age': [], 'Start date': [], 'salary': [], } for employee_data in table.find_all("tbody"): for row in employee_data.find_all("tr"): data['Name'].append(row.find_all("td")[0].text) data['Position'].append(row.find_all("td")[1].text) data['Office'].append(row.find_all("td")[2].text) data['age'].append(row.find_all("td")[3].text) data['Start date'].append(row.find_all("td")[4].text) data['salary'].append(row.find_all("td")[5].text) return data def PyRxCmd_doit(): try: db = Db.curDb() df = pd.DataFrame(scraper9000()) table = Db.Table() table.setDatabaseDefaults(db) table.setSize(df.shape[0]+2, df.shape[1]) table.setTextString(0, 0, "Scrape Master 9000") headers = df.columns.values.tolist() datas = df.values.tolist() for col, value in enumerate(headers): table.setTextString(1, col, "{}".format(value)) for row, data in enumerate(datas): for col, value in enumerate(data): table.setTextString(row+2, col, "{}".format(value)) model = Db.BlockTableRecord(db.modelSpaceId(), Db.OpenMode.kForWrite) model.appendAcDbEntity(table) except Exception as err: traceback.print_exception(err) 1 Quote
SLW210 Posted May 31, 2024 Posted May 31, 2024 Spammer removed. I was already suspicious of them. 1 Quote
