Hi, after having obtained the selection of a certain number of objects (for example because they are positioned on a certain layer) scattered in a very large autocad file, it is possible to exclude from the selection those external to a selection window or, which is the same result, keep only those in a select window?
Greetings
Using (ssget "WP" has the effect of selecting in a window or are you selecting a window as a second step.
If you're using the QuickSelect command, you can include or exclude the objects you select in the current selection set, rather than the entire drawing. You can also append them to the current set. In other words, you can add or remove batches of objects from a set in multiple steps. You may need to plan out the sequence of steps more carefully, for instance selecting with a window before selecting by layer.
Lisp Macro I've used for that purpose for 10 years now: (load "SSimWin.lsp") SSimWin
Select Similar within Window lisp function using SelectSimilar command by Alan J. Thompson, 2013.07.30.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/select-similar-by-window-selection/m-p/4348047#M313697
;| Select Similar within Window using SelectSimilar command by Alan J. Thompson, 2013.07.30.
(defun c:SSimWin (/ filter ss1 ss2 ss3 add i e)
  (setq filter (if (eq (getvar 'CVPORT) 1)
                 (list (cons 410 (getvar 'CTAB)))
                 '((410 . "Model"))
  (princ "\nSelect objects to select similar: ")
  (if (and (setq ss1 (ssget filter))
           (progn (princ "\nSelect area to select similar object(s) within: ")
                  (setq ss2 (ssget filter))
    (progn (command "_.selectsimilar" ss1 "")
           (if (setq ss3 (ssget "_I" filter))
             (progn (sssetfirst nil nil)
                    (setq add (ssadd))
                    (repeat (setq i (sslength ss3))
                      (if (ssmemb (setq e (ssname ss3 (setq i (1- i)))) ss2)
                        (setq add (ssadd e add))
                    (sssetfirst nil add)
Thanks Alan!
