LukeCAD Posted April 21, 2023 Posted April 21, 2023 Apologies if this has been asked before, perhaps i am searching using the wrong words. I am clicking the layout button, then on the layout viewports tab the 'insert view' 'New view' choosing my desired window, then CAD wants me to place the window or right click to choose scale, the default is from my scale list and is at 10:1 however I would like it to be 20:1 but it always defaults to the 10:1 even if i delete all from the scale list except the 20:1 and the 1:1 it defaults to 1:1 so every time i have to right click and select the scale, can this be set to what i want as default? Basically i wish to remove the need to right click every time. Quote
CyberAngel Posted April 21, 2023 Posted April 21, 2023 Have you looked into templates? You can create a layout with everything you need already in place. For your purposes, all you need is the scale, but you may find other uses. Apart from that, I'm not sure how you would bypass the scale specification. Quote
BIGAL Posted April 22, 2023 Posted April 22, 2023 (edited) Can be done manually pretty quick , dbl click go into mview and type Z 100XP that is 1:10 for me. Do a zoom 1st around objects then set scale. Edited April 22, 2023 by BIGAL Quote
