Hello everybody!
ive been meddling around with lisp trying to create a code that will draw lines on a predetermined grid of points (in order to draw a window or a door etc)
now the grid is made out of a set of points with letters for the Y pos and numbers for the X pos.
its all fine and dadny and its working great but it looks very ugly on script..
every point is made out of calculating the ratios given by the user for X and Y points, then converting it to a string.
(setq qx (nth 0 pt1))
(setq qy (nth 1 pt1))
(setq A1 (strcat (rtos qx 2 2) "," (rtos qy 2 2) ))
(setq B1 (strcat (rtos qx 2 2) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C1 (strcat (rtos qx 2 2) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D1 (strcat (rtos qx 2 2) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E1 (strcat (rtos qx 2 2) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F1 (strcat (rtos qx 2 2) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G1 (strcat (rtos qx 2 2) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H1 (strcat (rtos qx 2 2) "," (rtos (+ qy h_1)) ))
(setq A2 (strcat (rtos (+ qx (nth 0 spcs))) "," (rtos qy 2 2) ))
(setq B2 (strcat (rtos (+ qx (nth 0 spcs))) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C2 (strcat (rtos (+ qx (nth 0 spcs))) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D2 (strcat (rtos (+ qx (nth 0 spcs))) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E2 (strcat (rtos (+ qx (nth 0 spcs))) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F2 (strcat (rtos (+ qx (nth 0 spcs))) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G2 (strcat (rtos (+ qx (nth 0 spcs))) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H2 (strcat (rtos (+ qx (nth 0 spcs))) "," (rtos (+ qy h_1)) ))
(setq A3 (strcat (rtos (+ qx (nth 1 spcs))) "," (rtos qy 2 2) ))
(setq B3 (strcat (rtos (+ qx (nth 1 spcs))) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C3 (strcat (rtos (+ qx (nth 1 spcs))) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D3 (strcat (rtos (+ qx (nth 1 spcs))) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E3 (strcat (rtos (+ qx (nth 1 spcs))) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F3 (strcat (rtos (+ qx (nth 1 spcs))) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G3 (strcat (rtos (+ qx (nth 1 spcs))) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H3 (strcat (rtos (+ qx (nth 1 spcs))) "," (rtos (+ qy h_1)) ))
(setq A4 (strcat (rtos (+ qx (nth 2 spcs))) "," (rtos qy 2 2) ))
(setq B4 (strcat (rtos (+ qx (nth 2 spcs))) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C4 (strcat (rtos (+ qx (nth 2 spcs))) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D4 (strcat (rtos (+ qx (nth 2 spcs))) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E4 (strcat (rtos (+ qx (nth 2 spcs))) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F4 (strcat (rtos (+ qx (nth 2 spcs))) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G4 (strcat (rtos (+ qx (nth 2 spcs))) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H4 (strcat (rtos (+ qx (nth 2 spcs))) "," (rtos (+ qy h_1)) ))
(setq A5 (strcat (rtos (+ qx (- (/ w_1 2) (nth 4 spcs)))) "," (rtos qy 2 2) ))
(setq B5 (strcat (rtos (+ qx (- (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C5 (strcat (rtos (+ qx (- (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D5 (strcat (rtos (+ qx (- (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E5 (strcat (rtos (+ qx (- (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F5 (strcat (rtos (+ qx (- (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G5 (strcat (rtos (+ qx (- (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H5 (strcat (rtos (+ qx (- (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy h_1)) ))
(setq A6 (strcat (rtos (+ qx (- (/ w_1 2) (nth 3 spcs)))) "," (rtos qy 2 2) ))
(setq B6 (strcat (rtos (+ qx (- (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C6 (strcat (rtos (+ qx (- (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D6 (strcat (rtos (+ qx (- (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E6 (strcat (rtos (+ qx (- (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F6 (strcat (rtos (+ qx (- (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G6 (strcat (rtos (+ qx (- (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H6 (strcat (rtos (+ qx (- (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy h_1)) ))
(setq A7 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 3 spcs)))) "," (rtos qy 2 2) ))
(setq B7 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C7 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D7 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E7 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F7 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G7 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H7 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 3 spcs)))) "," (rtos (+ qy h_1)) ))
(setq A8 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 4 spcs)))) "," (rtos qy 2 2) ))
(setq B8 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C8 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D8 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E8 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F8 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G8 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H8 (strcat (rtos (+ qx (+ (/ w_1 2) (nth 4 spcs)))) "," (rtos (+ qy h_1)) ))
(setq A9 (strcat (rtos (+ qx (- w_1 (nth 2 spcs)))) "," (rtos qy 2 2) ))
(setq B9 (strcat (rtos (+ qx (- w_1 (nth 2 spcs)))) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C9 (strcat (rtos (+ qx (- w_1 (nth 2 spcs)))) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D9 (strcat (rtos (+ qx (- w_1 (nth 2 spcs)))) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E9 (strcat (rtos (+ qx (- w_1 (nth 2 spcs)))) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F9 (strcat (rtos (+ qx (- w_1 (nth 2 spcs)))) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G9 (strcat (rtos (+ qx (- w_1 (nth 2 spcs)))) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H9 (strcat (rtos (+ qx (- w_1 (nth 2 spcs)))) "," (rtos (+ qy h_1)) ))
(setq A10 (strcat (rtos (+ qx (- w_1 (nth 1 spcs)))) "," (rtos qy 2 2) ))
(setq B10 (strcat (rtos (+ qx (- w_1 (nth 1 spcs)))) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C10 (strcat (rtos (+ qx (- w_1 (nth 1 spcs)))) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D10 (strcat (rtos (+ qx (- w_1 (nth 1 spcs)))) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E10 (strcat (rtos (+ qx (- w_1 (nth 1 spcs)))) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F10 (strcat (rtos (+ qx (- w_1 (nth 1 spcs)))) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G10 (strcat (rtos (+ qx (- w_1 (nth 1 spcs)))) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H10 (strcat (rtos (+ qx (- w_1 (nth 1 spcs)))) "," (rtos (+ qy h_1)) ))
(setq A11 (strcat (rtos (+ qx (- w_1 (nth 0 spcs)))) "," (rtos qy 2 2) ))
(setq B11 (strcat (rtos (+ qx (- w_1 (nth 0 spcs)))) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C11 (strcat (rtos (+ qx (- w_1 (nth 0 spcs)))) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D11 (strcat (rtos (+ qx (- w_1 (nth 0 spcs)))) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E11 (strcat (rtos (+ qx (- w_1 (nth 0 spcs)))) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F11 (strcat (rtos (+ qx (- w_1 (nth 0 spcs)))) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G11 (strcat (rtos (+ qx (- w_1 (nth 0 spcs)))) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H11 (strcat (rtos (+ qx (- w_1 (nth 0 spcs)))) "," (rtos (+ qy h_1)) ))
(setq A12 (strcat (rtos (+ qx w_1)) "," (rtos qy 2 2) ))
(setq B12 (strcat (rtos (+ qx w_1)) "," (rtos (+ qy (nth 0 spcs))) ))
(setq C12 (strcat (rtos (+ qx w_1)) "," (rtos (+ qy (nth 1 spcs))) ))
(setq D12 (strcat (rtos (+ qx w_1)) "," (rtos (+ qy (nth 2 spcs))) ))
(setq E12 (strcat (rtos (+ qx w_1)) "," (rtos (+ qy (- h_1 (nth 2 spcs)))) ))
(setq F12 (strcat (rtos (+ qx w_1)) "," (rtos (+ qy (- h_1 (nth 1 spcs)))) ))
(setq G12 (strcat (rtos (+ qx w_1)) "," (rtos (+ qy (- h_1 (nth 0 spcs)))) ))
(setq H12 (strcat (rtos (+ qx w_1)) "," (rtos (+ qy h_1)) ))
in order to write it down i used google sheets and concatenated it with a table for easy copy pasting :D
again im super glad it works and i didnt get any issues with it.. but all im asking for is a better way of writing it all.
it was exhausting..
thnx in advance! love this forum
50 minutes ago, Mugna101 said:
 w_1
state
Please upload as attached the whole LSP you are dealing . and the sample DWG
3 hours ago, devitg said:
its a whole lot of script with almost nothing relating to this.
w_1 and h_1 are height and width that the user prompts,with spcs which is a list of numbers they determine the spaces between the spots of the grid.
using polylines in different combinations creates different shapes.
right now it is very very POC idea :~D
Edited by Mugna101
Like mhupp I have pick inside wall left side how far from corner, then enter all the values and a window is drawn the wall is broken as the dwg is 2 1/2D.
Happy to discuss the "Package" not free, but cheap.
Forgot to mention enter distance offset or Mid as a default.
Edited by BIGAL
11 hours ago, mhupp said:
Make dynamic blocks alot less work to get what you want.
Ive been attempting this first with the dynamic blocks but there are some issues im having there.. making a simple lisp to repetatively do something a block is a bit too limited for (i think)
im wondering why the 3d frame wont sit on the plan correctly...
are you using lisp for it?
The frame was drawn over a PDF as an exercise to show how to draw with Plan & Elevation views, using layouts and mview can look at all the elevations as roof is part of package. It was a demonstration for a potential client.
The software draws in a plan view but creates a more 3d model as it goes. AS walls have a height, windows and doors remove wall sections when added.
PM me if want more information.
Edited by BIGAL
