AeJay Posted April 13, 2023 Share Posted April 13, 2023 I currently have this idea about a dimension line adjustment tool but having a difficulty creating it. User will call this function and prompt the user of "Select D1" then the selected dimension line would be adjusted to 300mm (1:10 scale) then another prompt of "Select D2 " and then the selected dimension line would be adjusted to 200mm. Any time that the user enters any letter or just a blank, it will end the program and the basis for the distance would always be the dimension line connected to object (yellow rectangle) and not the dimension line connected to the holes inside the object (if there are any). Please help me with these as I am really on how to do this. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 14, 2023 Share Posted April 14, 2023 Please post only once this is like variation 2 of the other post. In my add holes this could be catered for. 1 Quote Link to comment Share on other sites More sharing options...
