I want Lisp to use -mapimport command with file path.... Thanks in advance
I want Lisp to use -mapimport command with the file path
Updated from here. https://www.cadtutor.net/forum/topic/31962-batch-import-shape-files/?do=findComment&comment=258808
Don't have maps so your going to have to trouble shoot what is needed.
(defun C:MAPMAPMAP (/ shpfile)
  (setq shpfile (getfiled "\nSelect a file: " (getvar 'DWGPREFIX) "kml,kmz" 16)) ;Starts in the drawing locaiton
  (command "-mapimport" "SHAPE" shpfile "n" "L" "S" (getvar 'clayer) "D" "C" "P" "P")
Change the (getvar 'dwgprefix) to a location if you want to start at the same location every time.
(setq shpfile (strcat (getenv "userprofile") "\\Documents\\")) ;this will default to documents in the user folder
or
(setq shpfile "C:\\Files\\mapstuff\\")
or
(setq shpfile "C:\\Files\\mapstuff\\file.mkl")
Edited by mhupp
