Change ALL dimensions to another existing dimension style?
ronjon did this in vlisp HERE
I was wanting to do something similar using regular lisp (to incorporate into a larger existing routine...) - I can maneuver a bit better in regular lisp being a novice too
I was hoping that this would work
(defun c:test ()
  (if (setq T3 (ssget "_X" '((0 . "DIMENSION"))))
    (repeat (setq n (sslength T3))
      (setq tdata (entget (ssname T3 (setq n (1- n)))))
      (entmod (subst '(3 . "NewDimStyle") (assoc 7 tdata) tdata)) ;;;NewDimStyle exists
(princ))
I changed an existing dimension style using the property manager and the only thing that seemed to change was Assoc 3 - ie: (3 . OldDimStyle)
My code does not work for me...
Is this a simple fix?
I found this in another post somewhere but did not know if you could mix vlisp/"regular" lisp (and don't know how)
(vla-put-Activedimstyle (vla-get-activedocument
                          (vlax-get-acad-object))
                            (vla-item (vla-get-dimstyles
                                 (vlax-get-acad-object))) "Name_dimstyle"))
Because it is going into another routine, I wanted to keep it as compact as possible..
Edited by ILoveMadoka
Should this be a 3 for the assoc and not a 7?
to be
(entmod (subst '(3 . "NewDimStyle") (assoc 3 tdata) tdata))
Dang! I was so close!!
You are my hero!!
..and Thank you!!
Close - the 2 parts have to match:
I personally hate it when someone has the same issue as me then posts "I fixed it!" and doesn't post their code...
Here is the final code:
(defun c:test ()
  (if (setq T3 (ssget "_X" '((0 . "DIMENSION")))) ; finds ALL dimensions
      (entmod (subst '(3 . "NewDimStyle") (assoc 3 tdata) tdata)) ;;;Assumes NewDimStyle exists / replaces the old Dimstyle with the new
(princ))
Thank you again Steven.
Thanks ILoveMadoka, hoping in this case that the discussion was clear - but a finished code makes the thread even better!!
It get's worse of course, people who post and asked a question in a single thread only and then delete their account so you can't ask them for a finished code later,
I walked away with not only my end goal met but I learned something as well...
